Results 1 to 6 of 6
Thread: Display Order
    2004-07
    2
    Default Display Order
    I am sure this is relatively simple, but I have used superhatch.in ADT 2, display order was relatively easy to find. It is very important to the final product. Does anyone know what happened to diplay order in ADT 4???? Thanks
    2003-03
    Philadelphia, PA
    2,392
    Default Re: Display Order
    DRAWORDER is the command in which you are interested. You can invoke it at the Command: prompt by typing it - DR is the command alias in the ACAD.pgp file that ships with ADT. It is also available from the context menus - select the object[s] you want to affect [grips on, none hot], then right click and then select Basic Modify Tools > Display Order > [desired option: Bring to Front, Send to Back, Bring Above Object or Send Under Object] from the context menus.
    See the attached JPG file for an image of the context menus in ADT2004.
    2004-07
    2
    Thank You to David Koch. Your answer worked beautifully. I really appriciate the help.
    Steven Ulstad
    100 Club wbs69117950's Avatar
    2006-07
    Saint Louis, MO
    120
    Quote Originally Posted by dkoch
    Is there still a toolbar for the DrawOrder in ADT2007? The Help shows a ToolBar, but it is impossible to find where it resides when trying to get the Toolbars to pop up. Help!
    BTW, I like the right click way. A little hard to find, 3 levels deep, but nice all the same. Problem is, I am working with luddites who refuse to use the right click for anything other than enter. Argh!
    Wesley
    Digital Delivery Director Brian Myers's Avatar
    2003-02
    Stillwater, Oklahoma
    1,819
    Quote Originally Posted by Wesley1969
    Sure Wes,
    The "DRAW ORDER" toolbar is still there, it's just located under the acad.cui
    To use this in your ADT environment you will need to load it into your ADT.cui via.. you guessed it... the CUI command.
    When the CUI loads up, go to the TRANSFER tab at the top.
    Load the ADT CUI on one side and the ACAD CUI on the other side.
    Open TOOLBARS on each side (expand it with the + symbol)
    Now click and drag Draw Order from ACAD.CUI over to ADT.CUI.
    Thats it. You'll now have it in your ADT as a Toolbar you can load and place where you need it.
    2002-09
    Madison, WI
    5,688
    Isn't that also located under the express tools as a command? If so (depending on how much you really like the Acad tool bar) you could just add it to one of your other custom tool bars or pallets. Just a thought.
  1. 2012: Display Order / Draw Order
    By Iceberg in forum AutoCAD General
    Last Post: 2013-08-08, 02:33 PM
  2. Display order in Display Manager
    By VBOYAJI in forum AutoCAD Map 3D - General
    Last Post: 2006-06-09, 02:12 AM
  3. Display Order
    By m_r_meza in forum Revit Architecture - General
    Last Post: 2005-10-16, 12:03 AM
  4. Display order - 2D on 3D
    By ioeser in forum Revit Architecture - General
    Last Post: 2004-12-21, 05:53 PM
  5. Display Order?
    By beboyle in forum Revit Architecture - General
    Last Post: 2004-02-06, 04:12 AM
