Im using ADT 2005 and under the "Plot and Publish" Tab in the options dialouge box you have the options selecting a specific default plot device or to use the last successful plot settings. even after I've set this options to the latter (use last successful settings) it doenst work. it either uses the default plotter or when you go to plot it selects the "none" plotter. Has anyone else come across this problem? and if they have do you have a soloution youd like to share.? Thanks in advance
