Is there a field to list the xref paths in a dwg as does the filename field?
I would like to be able to show all the xrefs to a dwg in the title block.
You could try using RText from the Express menu, that'll do that.Originally Posted by rmk
Hi
If required, additional information can be found in the following threads...
FIELDS, does this replace RTEXT?
List Xrefs in Field
Field - display the Xref name used for a View in the SSM
Have a good one, Mike
