Thread: Is there a way to 'fudge' the display of a curved grid?
    2006-09
    255
    Default Is there a way to 'fudge' the display of a curved grid?
    Hi
    In the attached I have a section on GL C6. I would like grids A-C to display but i understand the section view has to be perpendicular to the grids.
    Is there a way around this?
    Is the only/best way to create my own grid bubble family & grid line?
    TIA
    Dave F.
    2005-12
    566
    Default Re: Is there a way to 'fudge' the display of a curved grid?
    Dave:
    I think you have a slight geometry misalignment that is causing your arc grids to not show. I have a project with an arc grid, and as long as the section cut is perfectly perpendicular to the arc grid at its intersecting point, the arc grid will show up.
    The best way to do that is to draw a reference line from the center of the circle that the arc grids are on, and then draw your section grid on top of that reference line.
    Suffice it to say, yes, you should be able to see your arc grid lines in section.
  1. 2011: Curved UV grid?
    By damon.sidel in forum Revit - Conceptual Design Tools
    Last Post: 2012-04-27, 01:56 PM
  2. Curved Column Display Problems
    By WillE1984 in forum Revit Architecture - General
    Last Post: 2007-09-12, 04:04 PM
  3. curved curtain grid
    By RobG in forum Revit Architecture - General
    Last Post: 2006-03-28, 10:20 PM
  4. Map grid display
    By caduser in forum AutoCAD Map 3D - General
    Last Post: 2005-04-19, 04:52 AM
