Thread: Unexpected xclip behaviour, geometry inside disappear, geometry outside remains
    I could stop if I wanted to michael.12445's Avatar
    2001-03
    350
    Default Unexpected xclip behaviour, geometry inside disappear, geometry outside remains
    I'm using AutoCAD 2006, and trying to clip an xref with a polyline boundary. However, some of the geometry inside the boundary disappears, and some outside the boundary remains (see uploaded images) Is there a fix?
    Michael Evans
    Togawa Smith Martin Residential
    2001-03
    13,499
    Default Re: Unexpected xclip behaviour, geometry inside disappear, geometry outside remains
    Hi
    If it is possible, please post the actual DWG files so we may take a look at the issue / problem first-hand...
    Plus, you may wish to look at...
    ID: TS45628 - Portion of xref within clipping boundary is not visible
    Have a good one, Mike
    2001-03
    350
    Thanks Mike,
    Here's a zip archive of the host file (fp-2.dwg) and all its attached xrefs. The problem is at the location of the yellow polyline (near the top) that I'm trying to use as an xclip boundary.
    Thanks for your help,
    Michael Evans
    Togawa Smith Martin Residential, Inc.
  1. Modifying Geometry in ROBOT and Updating Geometry in REVIT
    By stephen.lewis in forum Robot Structural Analysis
    Last Post: 2009-12-09, 03:32 AM
  2. Egg-Like Geometry
    By Cheuk Ling in forum Revit Architecture - General
    Last Post: 2008-04-25, 05:13 AM
  3. Join Geometry
    By markf.68931 in forum Revit Architecture - General
    Last Post: 2005-11-29, 11:25 AM
  4. Redo an XClip when geometry is moved in Master file
    By jgratton in forum AutoCAD General
    Last Post: 2004-11-19, 04:47 PM
