Thread: Shake Siding Pattern
    2004-08
    180
    Default Shake Siding Pattern
    I know this has been discussed before but I can't find a decent and basic wood shake siding pattern. The one that ships with autocad that we've been using in Revit has a random horizontal bottom edge and really doesn't portray a traditional shake siding.
    I need one that is basically just horizontal lines spaced about 5" apart and random vertical lines. See attached.
    I would really appreciate it if someone could share one that they've made. It'd be even more great if someone has these in 5", 7" and 12" versions. And super super great if someone could post a .rvt file that already has the shake loaded so I can transfer project settings to my project.
    Thanks!
    I could stop if I wanted to hugh.69031's Avatar
    2004-06
    Melbourne, Australia
    245
    Default Re: Shake Siding Pattern
    Monochrome vertical and horizontal lines work fine (as expected ) with a raster import control we've currently under development for HatchKit. - quite good results can be attained from simple straight line images but vectorization rapidly becomes an adventure when curves or filled areas are attempted.
    The attached Revit Model pattern was scaled to give nominal 5" shake spacing - the whole 7-row pattern repeats in exactly 35" lifts.
    Do shakes get wider when spaced further apart or do they retain the same material width? Pardon my ignorance - shakes aren't often used here.
    Hugh Adamson
    Cadro Pty Ltd
    www.cadro.com.au
    2003-09
    1,907
    There are several hatch patterns for shakes/shingles posted in this THREAD. See if any can help
  1. Lap Siding
    By c.herd556236 in forum Revit Architecture - General
    Last Post: 2012-03-22, 05:18 PM
  2. Log siding
    By DoTheBIM in forum Revit Architecture - General
    Last Post: 2011-03-09, 12:17 PM
  3. Shake siding for model
    By Bill.Jensen in forum ACA General
    Last Post: 2006-09-17, 03:13 AM
  4. hatch pattern siding half round shake
    By cdmdwgpe.67574 in forum ACA General
    Last Post: 2005-06-16, 12:53 AM
  5. Need Model Pattern Shake, Straight cut
    By zanzibarbob7 in forum Revit Architecture - General
    Last Post: 2005-03-11, 10:28 AM
