Hi all,
I'm trying to edit my cui but i comes out as read only. I've gone to properties to uncheck the read only box but it still comes out as read only. Any ideas? Thanks.
kwong
Hi all,
kwong
Hi Kwong,Originally Posted by kwong
Is the cui set to be your Enterprise CUI or your Main CUI. If it is set to Enterprise, it will be read-only (I think, It is in Autocad; I'm not positive about LT). Type Options, then on the Files tab expand the Customization Files branch to check.
HTH
Thanks Tim, that certainly helps - you're right it's the same in LT.
kwong.
No problem.Originally Posted by kwong
Before you get too far, you might want to check out:
Notes on the Philosophy of the CUI
and Videos IN THIS THREAD
They will give some recommendations on how to set up custom CUIs.
HTH
