Thread: Sphere
    2004-08
    19
    Angry Sphere
    Can anyone help me create a sphere in Inventor 11, I need to fit 2 spheres on a length of pipe.
    Regards GM
    Manufacturing Moderator jonathan.landeros's Avatar
    2005-03
    Los Angeles County, Ca.
    440
    Default Re: Sphere
    Quote Originally Posted by gdmidgley
    Regards GM
    I usually create a sphere with a half circle and a revolve. A couple of suggestions on constraining would be to lock the sphere at the origin. Then you can use origin planes to help you locate the part.
    Here's a sphere I threw together in R11.
    Jonathan Landeros
    KETIV Technologies
    Orange County, California.
    I've got a blog: www.inventor-tales.blogspot.com
    “We have now left Reason and Sanity Junction.Next stop, Looneyville.” -Bob the Skull in the Dresden Files
    100 Club Commissar Rod's Avatar
    2006-01
    Harrisburg, PA
    137
    Default Re: Sphere
    I've always done the Half a circle-revolve method. Kindof a pain, but if you will be using it alot make it an I-Part
    The opening sequence to "Saving Private Ryan" was based on a game of dodgeball Chuck Norris played in 6th grade
    2004-08
    19
    Smile Re: Sphere
    Many thanks to you both for the information. simple when you know how. Thanks for the file.
    Regards Graham
    Williamsport, PA
    606
    Default Re: Sphere
    Quote Originally Posted by Commissar Rod
    No need to create iPart (or iFeature)
    Standard geometry is built into Autodesk Inventor Content Center.
    Start a new iam.
    Create a blank ipt component in the iam.
    Expand the ipt origin folder so that you can see the base workplanes in the browser. (This step is not needed if you are adding features to an existing part.)
    With the assembly level active
    select Place from Content Center
    Select geometry shape and enter size.
    Click the ipt workplane (or face of existing part).
    You will see a sketch of the feature or can still edit size or location.
    Exit sketch and your standard feature is created.
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    AU 2007 Avatech Altogether Smarter Inventor On-line Challenge 1st Place
    Autodesk Inventor Certified Expert
    Certified SolidWorks Professional
    Williamsport, PA
    2006-01
    Harrisburg, PA
    137
    Default Re: Sphere
    That is even better! Thanks!
  1. 2011: Primitive sphere
    By saidriad71 in forum AMEP General
    Last Post: 2011-09-23, 09:27 PM
  2. Primitive sphere
    By saidriad71 in forum Parts Builder
    Last Post: 2011-09-09, 04:56 PM
  3. VOID SPHERE
    By cwilrycx.109927 in forum Revit Architecture - General
    Last Post: 2010-02-27, 03:59 PM
  4. A Sphere on three points,,
    By boyerd in forum AutoCAD 3D (2007 and above)
    Last Post: 2010-02-17, 06:48 PM
  5. Sphere in Family editor
    By speedfreak5150 in forum Revit Architecture - General
    Last Post: 2009-03-16, 02:23 PM
