We've released a new version of Shortcut Highway compatible with Revit Architecture 2008.
http://www.digitalbuildingsolutions....way_about.html
When I go to your webpage I can not get some of the links to work. Is there an evaluation version because the download and history links do not work.
Does it check for duplicate entries with the same shortcut?
Thanks in advance for the help!
Kevin
Thanks for the new updated 2.3 version that I need to check out.
One area that is very interesting are the hidden commands you make available through the interface to set shortcut keys to. What exactly are these below?
Kevin
Shortcut Command Alternates
2D Family
Add default light
Add Spot Light Params
Add User Comment
Allocator Diagnostics
Analytical Support Tracker
Array Component
Array Detail Component
Auto Beam System
Auto Clip Elev
Autodimension
Autodimension All
Autofix Map
Backups
Balance Lighting
Building Constructions
Bulk Image Update
Catalog Organization
Check Default Constructors
Check Families
Check File Size
Check Geom Tables
Check Groups
Check Parse Accumulation Now
Clip Rect Screening
Column slaves
Compare All Sheets
Compare and Undo
Compare Files
Compare Print Results
Compare with Another
Compare XML files
Compute Occluded Elements
Content Tree Browser
Context Reuse Source Scan
Copy Selection to New File
Crash
Create Ad Hoc...
Create prototype shapes
Curve Based
Curve Driven (ref planes-based structure)
Dbg Dump Family File Data
Debug Mode
Delete Unused Fams and Symbs
Detail Component
Disable
Display Clip Region
Display Normals
Display Progress Meter
Double Click to Browse
Draw Tess Edges
Draw Tiny Objects
Draw Vector HLR
Draw XOR Text
Dump
Dump
Dump Bad Family Visibility
Dump Dependencies
Dump Loaded Families
Dump String Resources
Dump Unit Info
Dump Upgrade History
Edit and finish all in-place families
Edit and reload all loaded families
Element Compression
Enable Undo
Energy Analysis View
Energy Data
Episode Stats
Error Dialogs
Execute Shell Command
Exhaust VM
Expansion Statistics
Export additional info as XData
Export Element Id as XData
Export IFC
Export Types
Export veXML
Face Culling
Fam Elevation Fixed
Family Browser
Family delete
Family Types
Flush Undo
For each elem
Full
Heap Report
HLR
Host based slave syms (non-wall)
HVAC Loads
Image Compare
Image Compare Editor
Import IFC
Import Types
Insert 3d from File
Journal Registered Undeclared Iterations</t
Within the hidden commands for use, I have found some ones that are useful. See below.
Debug > Family > Family delete
Debug > Family > Save all loaded families
Debug > Product Information
Debug > Show Related
Debug > Show Related Warnings
Show related shows what relations a pick element has. Would be good for finding those constrainst that are not apparent. Save all loaded families saves all the families to a folder under the journal folder in a folder called "fam_save_last".
I am sure some of the other tools are useful also. This is a way to get under the hood a bit.
Check it out.
Kevin
use at your own risk...you have tapped into some utilities that are not normally exposed to the end user and are meant only for the development team.
Thanks for the information!
Kevin
