Thread: Rounding to the nearest integer in Tables
    2006-06
    20
    Default Rounding to the nearest integer in Tables
    I've created a table to calculate the occupant load for a building using fields to input the square footage. The problem I have is that the Life Safety Code requires that the occupancy be rounded up to the nearest integer but the table simply rounds off. It might round up, or it might round down.
    Is there a way to make the table round up?
    All AUGI, all the time Mlabell's Avatar
    2004-12
    Toledo, OH
    513
    Default Re: Rounding to the nearest integer in Tables
    Quote Originally Posted by kkinchen
    Hi kkinchen, try this link, and see if it helps.
  1. 2013: Rounding to nearest .5 in schedules
    By jplatte in forum Revit MEP - General
    Last Post: 2013-04-08, 06:30 PM
  2. Rounding up, down or to nearest... any interval
    By DoTheBIM in forum Revit Architecture - General
    Last Post: 2013-03-20, 03:07 PM
  3. Schedule Tables (Rounding)
    By Heather_W in forum ACA General
    Last Post: 2012-03-07, 01:46 AM
  4. Select case by integer - Restrict integer value to one
    By CADfunk MC in forum VBA/COM Interop
    Last Post: 2010-05-24, 08:02 AM
  5. Rounding up to the nearest 5
    By ReachAndre in forum AutoLISP
    Last Post: 2007-01-29, 06:56 PM
