Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Can't double click to edit text.
    2006-03
    San Cristobal, Guatemal
    439
    Default Can't double click to edit text.
    What got changed? I have to select, then issue the command to edit text or the reverse. I can no longer double click to edit text.
    Thanks
    2007-03
    Someplace
    46
    Default Re: Can't double click to edit text.
    Check the CUI under "double click actions" Under "Text" make sure the Edit macro is set to ^C^C_ddedit
    I could stop if I wanted to andy.manninen's Avatar
    2015-10
    @ _ork
    304
    Also check your DBLCLKEDIT variable, it should be set to 1(2005-) or ON (2006+).
    :Cheers:
    2006-03
    439
    That has not changed. What else could it be?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,103
    PICKFIRST? Haven't tried it but there are other Selection Modes (tab in the Options dialog) that may be affecting this.
    2005-08
    Albania
    423
    Quote Originally Posted by dlallen
    Thanks
    Is freeze the layer of text?
    And check the OPIE idea .
    Design Visualization Moderator stusic's Avatar
    2004-10
    Denver, Colorado
    1,515
    Quote Originally Posted by Opie
    I helped a co-worker out with this same problem yesterday. PICKFIRST was set to 0.
    2006-03
    439
    Thanks y'all, DBLCLKEDIT variable got changed. How does this get changed without going in and changing it?
    2008-02
    Maryland
    7
    Quote Originally Posted by andy.manninen View Post
    :Cheers:
    Quote Originally Posted by stusic View Post
    My DBLCLKEDIT=ON
    My PICKFIRST=1
    I am running Acad 2007, so I made sure my "Double click editing" box is checked.
    I still can not Double Click to edit text. Are there any other ideas?
    All AUGI, all the time Richard McDonald's Avatar
    2002-01
    At right angles to reality
    537
    Quote Originally Posted by tzinser View Post
    My DBLCLKEDIT=ON
    My PICKFIRST=1
    Quote Originally Posted by boffin View Post
    I think
  1. double-click for text edit
    By Maverick91 in forum AutoCAD Customization
    Last Post: 2015-02-27, 06:52 PM
  2. double click to edit text is broken.
    By slapthefunkyfour in forum Software
    Last Post: 2008-08-07, 09:07 PM
  3. double click edit is gone
    By clovis in forum AutoCAD Mechanical - General
    Last Post: 2007-10-10, 02:33 PM
  4. AutoCAD 2007 - Double click Text, Attributes to edit them
    By rflores.74287 in forum AutoCAD General
    Last Post: 2006-07-18, 06:14 PM
  5. Double Click to 'Edit'
    By Chad Smith in forum Revit Architecture - Wish List
    Last Post: 2004-10-27, 12:43 AM
