Results 1 to 7 of 7
Thread: convert String to List
    2005-02
    95
    Default convert String to List
    I have a problem with a list. I want to convert string to list.
    there is three nos. of data first member size, second its part no. and third is length of that member.
    "L50X50X6 45 4000" or
    "L100X100X8 92 2483"
    I want to convert it to list. like... (L50X50X6 45 4000) OR (L 100X100X8 92 2483).
    can it is possible.
    I could stop if I wanted to kpblc2000's Avatar
    2006-09
    211
    Default Re: convert String to List
    Look at the http://forums.augi.com/showthread.php?t=48298
    function _kpblc-string-parser
    Use AUTOCAD / ADT / AA 2006 / 2008 / 2010
    All i say is only my opinion
    I'm watching you! Your
    Try the following and see if it will work for you.
    Terry
    ; WordList - Returns a list of words in a sentence
    ; Arguments: 1
    ;   Sentence$ = String to convert into a list strings
    ; Syntax: (WordList "Words in a sentence") = (list "Words" "in" "a" "sentence")
    ; Returns: List of words or strings that were seperated by spaces in a sentence
    (defun WordList (Sentence$ / Cnt# Item$ Mid$ Num# ReturnList@)
      (setq Cnt# 1 Num# 1)
      (repeat (strlen Sentence$)
        (setq Mid$ (substr Sentence$ Cnt# 1))
        (if (= Mid$ " ")
          (progn
            (setq Item$ (substr Sentence$ Num# (- Cnt# Num#)))
            (if (/= Item$ "")
              (setq ReturnList@ (append ReturnList@ (list Item$)))
            );if
            (setq Num# (1+ Cnt#))
          );progn
        );if
        (setq Cnt# (1+ Cnt#))
      );repeat
      (if (not ReturnList@)
        (setq ReturnList@ (list Sentence$))
        (if (/= (substr Sentence$ Num#) "")
          (setq ReturnList@ (append ReturnList@ (list (substr Sentence$ Num#))))
        );if
      );if
      ReturnList@
    );defun WordList
    Active Member ElpanovEvgeniy's Avatar
    2006-09
    Russia, Moscow
    54
    (defun str-lst (s p)
     (if (vl-string-search p s)
      (str-lst (vl-string-subst "\"\"" p s) p)
      (read (strcat "(\"" s "\")"))
     ) ;_  if
    ) ;_  defun
    (str-lst "L50X50X6 45 4000" " ")
    (str-lst "L100X100X8 92 2483" " ")
    (str-lst "L50X50X6;;;45;;;4000" ";;;")
    (str-lst "L100X100X8-=Divider=-92-=Divider=-2483" "-=Divider=-")
    All AUGI, all the time CAB2k's Avatar
    2002-12
    Brandon, Florida
    687
    Nice code Evgeniy.
    Past Vice President peter's Avatar
    2000-09
    Honolulu Hawaii
    574
    This is my generalized solution for converting strings into lists, I use it with csv files.
    (csvstringtolist "this is my test" " ") returns '("this" "is" "my" "list)
    or or the comma separated
    (csvstringtolist "this,is,my,test" ",") returns '("this" "is" "my" "list)
    It also works for multiple letter delimiters like "**" or "\\"
    Peter
    (defun CSVStringToList  (strText strChar / intPosition lstStrings)
     (while (setq intPosition (vl-string-search strChar strText 0))
      (setq lstStrings  (cons (substr strText 1 intPosition) lstStrings)
            strText     (substr strText (+ intPosition 1 (strlen strChar)))
     (if lstStrings
      (reverse (cons strText lstStrings))
      (list strText)
    2002-12
    Brandon, Florida
    687
    Similar to the one I have.
    ;  parser by CAB multi char delim
    (defun sparser (str delim / dlen ptr lst)
      (setq dlen (1+ (strlen delim)))
      (while (setq ptr (vl-string-search delim str))
        (setq lst (cons (substr str 1 ptr) lst))
        (setq str (substr str (+ ptr dlen)))
      (reverse(cons str lst))
  1. Convert string to variable
    By davila.vanegas in forum AutoLISP
    Last Post: 2010-07-06, 12:42 PM
  2. Need to convert a string into a list.
    By Mike_R in forum AutoLISP
    Last Post: 2008-02-04, 05:56 PM
  3. convert a list to a string
    By ccowgill in forum AutoLISP
    Last Post: 2006-09-21, 10:18 AM
  4. Convert SUBR name in to a string
    By kennet.sjoberg in forum AutoLISP
    Last Post: 2005-08-22, 06:16 PM
  5. convert string to List
    By pnorman in forum AutoLISP
    Last Post: 2005-04-25, 03:46 PM
