Results 1 to 7 of 7
Thread: XREF MODIFY
    2004-06
    17
    Exclamation XREF MODIFY
    I am in an AutoCAD drawing which has a Referenced drawing attached. Inside that referenced drawing are dimensions strings. The dimension strings are defined so that the text is a different color than the dimension and extension lines, obviously for plot effect.
    I am able to "grey-out" all objects with colors defined BYLAYER. I cannot get my dimension text will not "grey-out" because the color is an override.
    Has anyone experienced this problem, and can you help me figure out how to overcome it.
    Thanks....
    2001-05
    Austin, TX USA
    2,201
    Default Re: XREF MODIFY
    If it's not bylayer in the original drawing, you can't change it. You will need to go into the original and change them to bylayer.
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
    2001-10
    Arizona
    2,337
    I beleive that if one issues the DIMSTYLE command there
    should display overrides, these ae coming from the CHILD
    xref file, you could edit those overrides in the PARENT drawing
    file and effect the change you desire.
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
    2004-06
    17
    Michael,
    that technique doesn't work. The dimstyles that are defined in the "child" drawing are not editable from the "parent" drawing. You would have to permanently change it in the "child"
    Glenn,
    thanks for the devastating revelation (Laugh). I'm stuck between a rock and a hard place. I have to figure out a way that for some disciplines to reference a drawing from another discipline, that has dimensions, and be able to "ghost-out" the dimension text, along with other object that have overriddden colors
    2001-10
    Arizona
    2,337
    Thanks, I thought the experiment I set up to test it worked.
    I think you will find that for inter-disciplinary file
    sharing that the best practice will always be color by layer
    linetype by layer. This may force you to create additional layers
    for maximum control.
    Be your Best,
    Michael Farrell
    2001-05
    Austin, TX USA
    2,201
    I would have to agree with Michael. Color and Linetype set to bylayer. Also nothing drawn on layer 0. I always hate it when xrefing someone else work, and they draw something on layer 0. You can't freeze layer 0 for a xref
    Glenn Pope
    Windows 7 Pro 64bit
    I explode MTEXT.
    2001-03
    13,499
    Hi
    Please note I've *moved* this Topic (Thread) from the AutoCAD Customization Forum to this one as I believe it would be better served here.
    Thanks, Mike
    Forum Moderator
  1. Replies: 3
    Last Post: 2012-07-12, 03:22 PM
  2. Modify Floors > Modify Sub Elements
    By diesellam in forum Revit Architecture - General
    Last Post: 2010-02-23, 12:53 PM
  3. 2008 SCALE 1:100 xref xref xref xref- scale list issues
    By Apsis0215 in forum AutoCAD Customization
    Last Post: 2008-11-21, 07:17 PM
  4. Modify xref path
    By rkmcswain in forum DWG TrueView - Wish List
    Last Post: 2006-03-16, 11:47 PM
  5. Replies: 12
    Last Post: 2005-08-10, 07:50 PM
