Originally Posted by
StephenJ
I have noticed when switching from ADT 3.3 (acad2002) to ADT 2006(acad2006), last year, when I press the up arrow to repeat a command (like a DOS key) it doesn't work all the time. If it is a command the function works fine but if it is a unit it doesn't.
For instance I used to type move, select objects, then select base point and when it would ask for the displacement I could type 13'4-3/8" and it would move 13'-4 3/8". Then if I wanted to do it again I could follow the process again and when it came time to enter the displacement I could use the up arrow and it would bring up the previous distance used. Now when I do this it gives me x/y coordinates. Is there a system variable or setting that allows me to set it to work the way I was used to having it work?
