It sounds like you are looking to pick a segment of a lwpolyline. What I've done in the past is explode a copy saving the info needed from the segment that snaps to the pick point, then deleting all the newly created objects leaving the origional polyline untouched.
(princ "\nSelect Line, Arc or Polyline segment ")
(setq ent (entsel))
(vl-cmdf "undo" "BEgin")
(setq eend (cdar(entget(entlast))) ; last entity
pt (cadr ent) ; selection point
ent (car ent) ; selected entity
obj (vlax-ename->vla-object ent)
EnTyp (cdr(assoc 0 (cdr(entget ent)))); entity type
;|Change pick point to midpoint to select newly created
line instead of original polyline with width.
(vl-cmdf "point" "mid" pt)
(setq pt(cdr(assoc 10(entget(entlast)))))
(entdel(entlast))
(vla-copy obj) ; Copy selected object.
(setq SS (ssadd (entlast)))
(if (= EnTyp "POLYLINE")(vl-cmdf "convertpoly" "Light" ss ""))
(if(or(eq EnTyp "POLYLINE")(eq EnTyp "LWPOLYLINE"))
(vl-cmdf "explode" (entlast)) ; Explode the copied object.
(setq elist (cdr(entget (ssname (ssget pt) 0))) ; Entity list of selected segment.
EnTyp (cdr(assoc 0 elist)) ; Entity Type of selected segment.
(while(not(eq (entlast) eend))
(entdel(entlast)) ; Delete everything that we added so far.
Of course if you know for sure you're looking for the second segment of the lwpolyline that would be easyer. You wouldn't need to make a copy just extract the information directly.
