Thread: HIDE TEXT PROBLEMS
    2004-07
    6
    Default HIDE TEXT PROBLEMS
    Can anyone help this has been driving me mad for a long time!
    When plotting a hidden view my text always loses its text fill and prints just an outline, regardless of the TEXTFILL and HIDETEXT settings.
    When I upgraded to ADT2005 I noticed you could exclude text from hide operations by de-selecting the tick box in HLSETTINGS. This worked fine initially and hidden plots displayed text correctly. I have tried it again recently (on two seperate machines) and now I have the original problem back (it seems to ignore the include text from hide operations variable).
    Any help would be gratefully received.
    Graham.
    150700
    3,421
    Default Re: HIDE TEXT PROBLEMS
    Please note, this thread was moved at the authors request.
    2001-03
    13,499
    Hi
    Check out the following Technical Documents on the Autodesk web site under the Knowledge Base section -
    ID: TS67839 - Settings that control printing of filled text and solid hatches
    ID: TS74623 - Text fill does not show in plot or plot preview when plotting from paper space
    Have a good one, Mike
    2004-07
    6
    Those links all suggest that it is not possible to have text fill when plotting a hidden view, which I need to do regularly. I always accepted this was the case until I upgraded to 2005 and tried turning the Include Text in Hide Operations off. This appeared to get the result I wanted (a hidden plot with text fill in the same viewport). I’ve now tried it again and its not working now. If I hadn’t had a colleague present at the time id think i had imagined it!
    Thanks for your help!
    Graham.
  1. problems with TEXT - text widen/anlerge without my action
    By Macieto in forum AutoCAD General
    Last Post: 2009-07-30, 07:46 AM
  2. Text problems with DWF's
    By Miss Beth in forum AutoCAD Plotting
    Last Post: 2008-10-28, 07:35 PM
  3. Hide/Show Text
    By dduarte in forum Revit Architecture - General
    Last Post: 2006-05-11, 09:51 PM
  4. Wipeout Text Problems
    By lmitsou in forum AutoCAD Map 3D - General
    Last Post: 2005-03-21, 01:09 PM
