Thread: Perpendicular & nearest won't snap to arc
    2016-01
    88
    Default Perpendicular & nearest won't snap to arc
    One of our users has a drawing in which the osnaps are behaving strangely. When trying to draw a line from off an arc (but not at it's center) to the arc, if the osnap is set to either perpendicular or nearest there are some arcs that Acad will not find the snap, it doesn't even show the snap icon for perp or nearest when you hover near them! All of the arcs are at zero elevation. I opened the drawing on my computer, and I am having the same problem, but only with this drawing. Endpoint and midpoint snaps work fine, but perp and nearest will not work. I have tried with both running osnaps, and with just one osnap set, but can’t get them to work. Is there some setting I am unaware of? All the snaps seem to be fine if I snap to a line rather than an arc.
    2005-08
    Albania
    423
    Default Re: Perpendicular & nearest won't snap to arc
    Quote Originally Posted by gadjet
    It is good to attach this drawing where can I do something.
    All AUGI, all the time CADDmanVA's Avatar
    2006-12
    New Orleans, LA
    881
    I'll agree with Arben, posting the drawing in question does help.
    But...to take a stab at it anyhow...
    1. Try doing an AUDIT and RECOVER on the drawing. Perhaps there's an error in it.
    2. What happens if you WBLOCK the entire drawing out and insert it into a new, blank drawing?
    Give these a whack and let us know, and/or post the drawing.
    2006-01
    Harrisburg, PA
    137
    Does it work if you use a osnap override for the one you want?
    2006-01
    202
    Do the arcs have an extrusion relative to the UCS when listed?
    It sounds as if its the kind of thing which crops up with arcs on non 0 z values which have been flattened maybe. Flattening them will sometimes leave them seen as 3d entities to AutoCAD even though they sit at 0 z value.
  1. Perpendicular 2D snap to line
    By Tom Beauford in forum AutoLISP
    Last Post: 2013-05-17, 03:31 PM
  2. Make running osnaps always snap to the nearest matching snap point
    Last Post: 2012-06-17, 05:54 AM
  3. Nearest Snap Problem
    By tblack.62739 in forum AutoCAD CUI Menus
    Last Post: 2005-09-01, 05:42 AM
  4. Perpendicular Object Snap
    By SHEILA in forum ACA General
    Last Post: 2004-10-06, 06:41 PM
  5. Deferred Perpendicular Snap
    By rpetrie in forum AutoCAD General
    Last Post: 2004-10-04, 07:13 AM
