Results 1 to 6 of 6
Thread: Dynamic Input, unable to input surveyors bearings in the SE or SW quadrant
    2004-06
    Lacombe, Louisiana
    137
    Default Dynamic Input, unable to input surveyors bearings in the SE or SW quadrant
    Does anyone know why you can't input a surveyors bearing in the SE or SW quadrant when using dynamic input. It works in the NE and NW quadrant but not the other two. Any suggestions would be appreciated.
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Default Re: Dynamic Input, unable to input surveyors bearings in the SE or SW quadrant
    Quote Originally Posted by rmk
    Hi,
    Are you using this format?
    From help:
    Work with Surveyor's Angles
    If you use surveyor's angles when specifying polar coordinates, indicate whether the surveyor's angles are in the north, south, east, or west direction. For example, to enter a coordinate relative to the current coordinate for a property line that is 72 feet, 8 inches long with a bearing of 45 degrees north, 20 minutes, 6 seconds east, enter
    @72'8"<n45d20'6"e
    Tim Creary
    S&D
    DILLIGAF
    2004-06
    Lacombe, Louisiana
    137
    Actually, I am trying to tab between the input boxes and enter the necessary info in the boxes themselves. I have always input it like you show at the command line, but i was hoping to get away from doing that.
    AUGI Addict .chad's Avatar
    2006-04
    is it lunch time yet?
    1,125
    you can just keep entering the information, you dont need to tab through them. when you type the @ and < it jumps to the appropriate box.
    This aggression will not stand. Man.
    2004-06
    Lacombe, Louisiana
    137
    What i was doing was invoking the line command, picking a point on the screen and moving the cursor to another point on the screen without pressing any mouse button, tabbing through the input boxes (not using the @ or< symbols, just entering a distance and S65d15'E and then pressing enter. the line would be drawn in the nw quadrant at a different bearing.
    2006-04
    1,125
    i just tried two lines here with your bearings, one tabbing through and one using @ and < and both came out fine, and appeared to be in the correct quadrant. its possible that you just need to move your line so the opposite end hits the current point - i have seen that happen more than once. i dont really know why it does that, we only covered surveying in one class and i pretty much forgot all of that stuff as soon as i finished the test.
  1. Dynamic Input
    By tiffany.amorgan in forum AutoCAD General
    Last Post: 2010-01-11, 05:22 PM
  2. Dynamic Input
    By dzatto in forum AutoCAD General
    Last Post: 2007-09-27, 06:09 PM
  3. Input bearings when using dynamic input
    By rmk in forum AutoCAD General
    Last Post: 2006-03-13, 03:39 PM
  4. Dynamic input
    By MikeM4OSU in forum Dynamic Blocks - Technical
    Last Post: 2005-11-29, 02:46 PM
