Results 1 to 10 of 16
Thread: Unreconciled Layers, can someone please explain what they are
    2002-03
    Sacramento Ca.
    424
    Default Unreconciled Layers, can someone please explain what they are
    Another 08 issue. When opening any files from older versions, (ADT 07, 06), I get a message saying there are "New Unreconciled Layers". When I click on the icon on the bottom right corner with the exclamation point, it says click here to see new unreconciled layers. OK, great, here they are. What the hell are they and what am I supposed to do about it? All I know for sure is that these particular layers won't plot.
    Please help.
    Thanks,
    Phil
    Time Lord Steve_Bennett's Avatar
    far, far, far away...
    4,730
    Default Re: Unreconciled Layers, can someone please explain what they are
    Please note I am moving this to the AutoCAD 2008 general forum.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    4,730
    Unreconciled layers is a new feature for the layer manager box introduced for AutoCAD 2008. You can either use the feature or turn it off. You need to go into the layer manager to do this.
    Digital Delivery Director Brian Myers's Avatar
    2003-02
    Stillwater, Oklahoma
    1,819
    Take a look at this link for a better understanding of Unreconciled layers:
    http://heidihewett.blogs.com/my_webl...notificat.html
    Its used to track/manage newly added layers.
    Tallahassee, FL USA
    3,658
    Take a look at the system variables "layereval" and "layernotify".
    Also go to http://www.jtbworld.com/autocad2008.htm and scroll down to Layer Notification, Jimmy Bergmark has written a routine to remove this feature from a drawing.
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    To answer your immediate question, when you get warned of "Unreconciled layers", go ahead and look at them. Select them all, and then right-click and select "Reconcile layer".
    It's quite annoying, but we've been leaving it on for now. We're starting to think this feature might be useful, but the default behavior Autodesk implemented this time around is more annoying than anything.
    It's designed to deal with the problem created when new linework is added to an XREF. For example, you create a plan set that XREFs in a base file. The plan set is finished, but the project is not finished. So you continue working, and add more stuff to your base file. Now you need to print out that early plan set again. If you simply print it, it will contain all the new linework you added to the base file. This might cause problems, such as text overtyping, and it might be data that is not supposed to be in the early plan set. This feature is designed to warn you of that.
    However, that means it is worthless UNTIL you hit the point that you want to "freeze" a plan set. So it really should be an option that is turned OFF by default, and is something you can turn ON when you reach a point that your plan set is considered "complete", and you actually WANT the warning that new layers have been added to your XREFs. There should also be a button that says "Reconcile all layers and plot", rather than that obnoxious dialog that forces you to either look at the unreconciled layers or cancel the plot.
    2007-11
    Smile Re: Unreconciled Layers, can someone please explain what they are
    To get rid of the annoying unreconciled Layer pop up,
    -Search C drive for "acad2008doc.lsp"
    -Open with notepad.
    -Scroll down to bottom of page and paste:-
    (setvar "layereval" 0)
    (setvar "layernotify" 0)
    -Save and close
    -Restart AutoCAD
    Now the Message will not show again.
    I could stop if I wanted to mom of 3's Avatar
    2004-07
    jUSt in the middle
    366
    Quote Originally Posted by sinc View Post
    oooooooooohhhhhhhhhh, so THAT'S what that's for!!!!!!! we actually do have a lot of that going on with our projects (multiple stages).........too bad most of them are not in 2008 yet, though.
    9,803
    Quote Originally Posted by matthew.smith View Post
    Search ... for "acad2008doc.lsp"
    1. You should not edit "acad200xdoc.lsp". This file belongs to AutoCAD is is subject to being overwritten during a repair, reinstall, upgrade, etc. Use "acaddoc.lsp" for user added functionality.
    More info:
    http://support.autodesk.com/getdoc.asp?ID=TS21336
    http://support.autodesk.com/getdoc.asp?ID=TS28079
    2. LAYEREVAL and LAYERNOTIFY are drawing saved system variables. Setting them at startup will change DBMOD. This is undesired in most cases. Drawing saved sysvars should be set in the template drawing(s) when possible.
    9,803
    It's also worthless when you PUBLISH a set of drawings.
    1. You don't get the warnings.
    2. It wouldn't help if you did, since the whole point of PUBLISH is not having to open each drawing.
    Another way to achieve the same results... FREEZE all layers in xref drawings (before creating the xref). Then in order for new geometry to show up, you have to go into the parent drawing and THAW it.
    Works if you need the new geometry to show up in 1 out of 100 sheets. Not so good if you need it to show up in 50 or 75 of the 100 sheets.
  1. unreconciled new layers
    By minhtct in forum AutoCAD General
    Last Post: 2011-09-12, 06:16 PM
  2. Unreconciled Layers
    By mgonzales.224492 in forum AutoLISP
    Last Post: 2011-02-14, 10:52 PM
  3. Unreconciled Layers
    By Eddy B in forum Project Navigator
    Last Post: 2008-10-12, 06:06 AM
  4. Unreconciled layers ????
    By rkc in forum ACA General
    Last Post: 2008-01-03, 11:23 PM
  5. Unreconciled layers????
    By vanderloo5 in forum ACA General
    Last Post: 2007-05-08, 10:26 PM
