True, but I avoid that so that no code that does modify the drawing ever sneaks into our startup code.
R.K. McSwain | CAD Panacea |
type in "layernotify" and set the variable to "0" that will stop the pop ups in the drawing
That was already established in this post
The problem is that this sysvar is saved in the drawing. If your template drawing has been set to 1, then all your working drawings have it set to 1 also.... forcing you to change it in each existing working drawing...
The suggested solution is in the last sentence of #2 in this post
I know this is a bit late but with acad 2009 set layerevalctl to 0. It's saved in the user settings not the drawing, so do it once and you are done.
