Results 1 to 9 of 9
Thread: Stretch not working when Rotated
    Member BRENDA_GZZ_GOMEZ's Avatar
    2007-04
    15
    Unhappy Stretch not working when Rotated
    I need help with a block that I've created. I want to be able to rotate and stretch the line and triangle. But for some reason my stretch is acting up.
    AUGI Addict .chad's Avatar
    2006-04
    is it lunch time yet?
    1,124
    Default Re: Stretch not working when Rotated
    imo - a polar stretch would be more efficient than a seperate stretch / rotate. if you dont do that, you just need to double check you selection sets. probably easiest to just rebuild the stretch and rotate actions.
    This aggression will not stand. Man.
    All AUGI, all the time Mlabell's Avatar
    2004-12
    Toledo, OH
    513
    Quote Originally Posted by BRENDA_GZZ_GOMEZ
    You just need to remove the actions from rotate selection set. To do so, double click the rotate action, and key in "r", then select the stretch and flip actions. Everything will then work as intended. Just to let you know adding actions to another actions selection set can yeild some whacky results.
    Dynamic Blockhead Mod Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    to answer your question, remove all affected actions by actions.
    to check what i mean: select an action. if it highlights another action, double click, type 'r' (remove), enter, then select the action to remove it from the set. with stretches, just hit 'enter' to keep the stretch window defined as is and move onto the selection mode.
    your block worked fine once i removed all the 'lightning' actions from under other actions.
    S&D DB Sharing Forum
    2001-12
    Rochester, MN
    2,561
    Quote Originally Posted by marklabell
    ah, so you HAVE been paying attention!!
    i actually remove ALL actions from under actions unless they're independent basepoint actions. (modified scale & rotate)
    2001-12
    Rochester, MN
    2,561
    Quote Originally Posted by Chad_C
    actually, for section cuts, i still preferr the rotate/linear combo. don't have to worry about the line going slightly out of line from direction i'm wanting...
    2004-12
    Toledo, OH
    513
    Quote Originally Posted by Chris.N
    You know it. The DB info you have been putting out in AUGI is my heroin. I'll shut it before I inflate the ego!
    2006-04
    1,124
    set your angle increment to something nice and round, say... 15 degrees.
    acutally come to think of it - our section cuts are two seperate actions also. (probably because they are heavily borrowed from yours in the first place ) /shrug
    2007-04
    15
    Talking Re: Stretch not working when Rotated
    THANKS FOR ALL OF YOUR HELP
  1. Stretch an Object orthogonally after it has been rotated
    By cadconcepts in forum Dynamic Blocks - Technical
    Last Post: 2008-02-22, 07:14 PM
  2. Export to dwg of rotated views not working ?
    By juha-pekka.rindell in forum Revit Architecture - General
    Last Post: 2007-01-31, 03:32 PM
  3. Polar Stretch not working as expected
    By judekw in forum Dynamic Blocks - Technical
    Last Post: 2006-11-21, 08:53 PM
  4. Grips stretch not working with OSNAPS
    By bmonk in forum AutoCAD General
    Last Post: 2006-07-11, 03:44 PM
