Results 1 to 8 of 8
Thread: Link a value in a Table to a Field, so Field updates if Table value changes
    2006-07
    2
    Question Link a value in a Table to a Field, so Field updates if Table value changes
    I'm trying to create a table in AutoCAD 2007 that can update a field if I changed the contents in the table. For instance I've got first floor elevations, invert elevations, centerline elevations, etc... that are referenced multiple times in a drawing and I wanted to create a table with all the elevations and when I change the elevations in the table they would update in a field. Any help would be great, thanks!
    2001-03
    13,499
    Question Re: Link a value in a Table to a Field, so Field updates if Table value changes
    Hi
    You should be able to link the contents of a Table cell to a Field Object.
    What exactly are you after achieving? The more detailed information you are able to supply, the better chance of someone being able to provide a solution to your particular requirements.
    Have a good one, Mike
    Houston
    7,519
    Default Re: Link a value in a Table to a Field, so Field updates if Table value changes
    Quote Originally Posted by Mike.Perry
    Can you show us how? Thanks.
    Houston
    7,519
    Quote Originally Posted by clucas.116254
    Do you have to use a TABLE object?
    If not, you can create your text, make a block out of it, then insert the block into all the places you need it.
    Then if you have to change it, you simply edit the block definition using ._BEDIT.
    All AUGI, all the time zoomharis's Avatar
    2005-02
    Abu Dhabi (Native-India)
    506
    Quote Originally Posted by rkmcswain
    Of course, you can do that. Use the Cell button inside the Formula category of the Field object. See the attached sample drawing.
    HTH
    har!s
    CADing && Coding
    AuotCAD 2010 on Windows XP Professional (SP3)
    Houston
    7,519
    Talking Re: Link a value in a Table to a Field, so Field updates if Table value changes
    Quote Originally Posted by zoomharis
    Cool. I knew it could be done since the other poster said so. Thanks for the example.
    2006-03
    Midland, MI
    335
    Quote Originally Posted by zoomharis View Post
    HTH
    I know this is a few years after the fact, however it is an issue just the same today as it was 5 years ago. I would add the question; can this be done across different layouts as well as between layout and model space? Also, can two or more tables be linked in the same convention? Please advise, Thank you!
    Cairo - no, not Illinois
    2,714
    simplest thing would be to use DWGPROPS, put the value there,and have the fields reference it. presuming that you don't have a humongous number of values to work with
    Officially Awesome
  1. Attribute Value extraction into Table Field
    By steven_mott33 in forum Dynamic Blocks - Technical
    Last Post: 2010-09-04, 10:25 PM
  2. Math error in table field
    By michael.12445 in forum AutoCAD Fields
    Last Post: 2010-06-08, 10:12 AM
  3. Table / Field link issue
    By bgrinnell in forum AutoCAD Tables
    Last Post: 2010-03-15, 04:04 PM
  4. Field reading data from table.
    By amoroz in forum AutoCAD Fields
    Last Post: 2009-11-17, 04:41 AM
  5. Linking text value in table to a field
    By lpseifert in forum AutoCAD Tables
    Last Post: 2007-08-06, 08:32 AM
