ti598
Hey guys, following my recent updates on the Corus (UK) Structural Steelwork blocks, I am stuck on the last one, the joist section.
On the attached drawing, there are 2 db's; the one on the right has all the sizes set up as vis states while the left hand one is the db I'm trying to create using lookup parameters. I've got everything working except getting the angles lines on the inside of the flanges to stretch correctly.
Could someone help me to fix this? I'm thinking the only way around it is to have a length parameter for the line and 2 distance parameters from the outer line of the flange to either endpoint of the lower line if that makes any sense.
Cheers in advance
Paul K
