Thread: Change visibility setting of Dynamic Block inserted into a cell of a Table
    2006-06
    20
    Question Change visibility setting of Dynamic Block inserted into a cell of a Table
    When I insert a dynamic block into a table cell, AutoCAD does not allow me to change the visibility setting in the block. Is there a way to do this?
    AUGI Addict .chad's Avatar
    2006-04
    is it lunch time yet?
    1,129
    Default Re: Change visibility setting of Dynamic Block inserted into a cell of a Table
    i dont think you can. they dont work in multi-leaders either.
    2008-10
    London, UK
    103
    Still not able to do this. This is a real annoyance for me.
    Rant over.
    2006-11
    A workaround that I’ve discovered for the inability to change visibility states of a dynamic block in a table cell is to insert the block in the drawing, change the visibility to the way you want it. Then, copy and paste as a block. Get the name assigned name of the pasted block (eg A$C0861780C). Use this name to insert the block into the table cell.
    I just checked 2016 to see if it was changed. It hasn't so the workaround still applies.
    Cheers
  1. Replies: 4
    Last Post: 2015-03-23, 09:11 AM
  2. Change Visibility of Dynamic Block Using Sheet Set Field
    By seneca06 in forum AutoCAD Customization
    Last Post: 2014-11-20, 01:26 PM
  3. Replies: 0
    Last Post: 2013-10-31, 08:42 PM
  4. Modify Dynamic Block Properties within a Table Cell
    By ccowgill in forum AutoCAD Tables
    Last Post: 2008-05-22, 05:15 PM
  5. Lock visibility state once Dynamic Block has been inserted
    By clarkrj in forum Dynamic Blocks - Technical
    Last Post: 2006-05-04, 01:24 PM
