Thread: Create Custom Drawing Properties that keep the case of the string given?
    2003-03
    Alberta
    248
    Default Create Custom Drawing Properties that keep the case of the string given?
    How can I create Custom Drawing Properties that keep the case of the string given?
    I have a function that modifies the custom properties of a drawing to add a new property with a given value. My problem is that when the property is added the name is always created using lower case. This is a problem because I have another routine that creates text to show the values of the drawing properties and the field codes are expecting case sensitive names.
    Here's a snippet of my code to create the custom property.
    Dim Builder As New AcadDb.DatabaseSummaryInfoBuilder(Dwg.Database.SummaryInfo)
    Dim Name as String = "My Prop"
    Builder.CustomProperties.Add(Name, Value)
    When I look in the Custom Properties "My Prop" has changed to "my prop". What's going on?
    AutoCAD 2010
    AutoCAD Map 2010
    MS Visual Studio 2008
    2003-03
    Alberta
    248
    Exclamation Re: Create Custom Drawing Properties that keep the case of the string given?
    OK, the problem is bigger then I thought. When I use the ToDatabaseSummaryInfo method from Builder to update the drawing, all of the Custom Property keys are changed to lower case. This wreaks havoc across my drawing as any fields now show the #### as they are looking for the Cased Key Names.
    Here's my complete function.
        Public Function SetCustomProperty(ByVal Dwg As Autodesk.AutoCAD.ApplicationServices.Document, ByVal Name As String, ByVal Value As String) As Boolean
            Dim Builder As AcadDb.DatabaseSummaryInfoBuilder
            Builder = New AcadDb.DatabaseSummaryInfoBuilder(Dwg.Database.SummaryInfo)
            Try
                If Builder.CustomProperties.ContainsKey(Name) Then
                    Builder.CustomProperties.Item(Name) = Value
                Else
                End If
                Dwg.Database.SummaryInfo = Builder.ToDatabaseSummaryInfo
            Catch
                Return False
            End Try
            Return True
        End Function
    Suggestions please!
    AutoCAD 2010
    AutoCAD Map 2010
  1. Need program for adding custom properties to a line in a drawing
    By chaitanya.1217767394 in forum VBA/COM Interop
    Last Post: 2012-02-21, 08:23 PM
  2. Replies: 8
    Last Post: 2006-12-12, 11:20 AM
  3. Replies: 12
    Last Post: 2006-09-18, 09:59 PM
