Results 1 to 6 of 6
Thread: Cannot create Tool Palettes from Design Center anymore?
    2006-03
    15
    Default Cannot create Tool Palettes from Design Center anymore?
    I've set up a few different tool pallets from design center a while ago, and for some reason, now when I update the drawing with my blocks and try to re-create the tool palette it doesn't work right.
    It creates an empty palette, but it names it correctly.
    Anyone have any ideas??
    2001-03
    13,499
    Default Re: Cannot create Tool Palettes from Design Center anymore?
    Hi
    For starters take a look at the following couple of threads...
    Unable to create a Block Tool Palette from Design Center
    In Design Center I am unable to convert a folder into a Tool Palette content
    Have a good one, Mike
    2006-03
    15
    Neither of those threads helped me, I think my problem could be a little different. I can insert blocks and use commands of the existing palettes that I created a while ago, I can also add blocks to the palette from Design Center, but for some reason the only thing I cannot do is right click on a folder or a drawing and "create tool palette".
    I shouldn't have to re-install to fix this problem, or at least I would rather not do that. Does anyone have any ideas?
    Attached is a video of what's going on with my palettes.
    100 Club Commissar Rod's Avatar
    2006-01
    Harrisburg, PA
    137
    What program did you use to record your video? (i'm a novice when it comes to video capture). I unfortunatly do not have an answer for your question but seeing how you did that does provide a solution for me to a training problem we were debating on.
    The opening sequence to "Saving Private Ryan" was based on a game of dodgeball Chuck Norris played in 6th grade
    2006-03
    15
    It's a great program called Camtasia. I also use it to make training videos. It works great, you can also put audio to it.
    2007-03
    I am also experiencing the same problem with our tool pallets.
    Was this problem ever resolved?
    I can drag new blocks onto an existing pallet, but for some reason can not drag blocks onto a newly created tool pallet.
    Dave
  1. Unable to create new tool palettes
    By vicki.beynon270201 in forum AutoCAD General
    Last Post: 2011-03-17, 11:49 AM
  2. added 2nd display, now tool palettes jump to center of screen
    By jameswest77 in forum Revit Architecture - General
    Last Post: 2010-09-20, 04:09 PM
  3. Design center - Create tool palette
    By Bryan Thatcher in forum ACA General
    Last Post: 2009-12-09, 08:36 PM
  4. Replies: 6
    Last Post: 2006-11-21, 11:30 PM
  5. Unable to create a Block Tool Palette from Design Center
    By BrenBren in forum AutoCAD Customization
    Last Post: 2006-02-07, 08:37 PM
