Hi
RS4
is the insulation command that is under Drafting in Revit Building available in Structure?
I've looked by can't find it.
Is it a repeating detail?
Cheers
Dave F.
Hi
RS4
Cheers
Dave F.
This is odd. If you look under the Settings -> Line Styles... dialog, it lists Insulation Batting Lines. Therefore it should be a Detail Lines on the Drafting Design Bar but it does not list it in the type selector.
Dave, this tool is not currently available in Revit Structure.
Insulation Batting is not found in RS 4.
The line types that are created in revit are only through dashes at present.
I've found I can bodge it by copy/pasting the Architects line into my model & manipulating it from there. I can edit the width & the 'hoop' ratio so all well & good.
