Results 1 to 7 of 7
Thread: WINDOW FAMILY FOR CURVED WALL
    2005-08
    Nelspruit, South Africa
    26
    Red face WINDOW FAMILY FOR CURVED WALL
    What is the best way to make a window family that can be inserted into a curved wall as per the attachment. Attachment done using curtain walls which don't show up in a window legend. I hope someone understands what I'm trying to get at.
    Perhaps there's an existing thread that's already dealt with similar?
    Gary
    Member AffordableDesignsCo's Avatar
    West Sacramento
    33
    Default Re: WINDOW FAMILY FOR CURVED WALL
    It looks to me like you would create the window as a family with the frame as either curved or several straight pieces connected to follow the curve. once the frame is made you can create a curved glass (too expensive) or create the glass as an extrusion to meet your needs. This is like builiding any other window but with many more parts and details. all components of the family appear to be solid sweeps unless you are seeking true curved trim. The best plan is to design it like the manufacturer will build it. Decide what you want them to do, then draw each item.
    2002-09
    165
    Hi
    You can use a normal window template to create a 'curved window' like the one i have attached. You need explore the family to understand the process. See the image file as well.
    Xavier G Papuraj
    Sydney, Australia[/B][/SIZE]
    'Know enough to know that you don't know everything!!'
    I could stop if I wanted to whittendesigns's Avatar
    2004-07
    330
    OK, you've intrigued me papurajx. very interesting what you posted, but I can't see how this works. I tried inserting it and it's roughly perpendicular to the surface of the wall.
    2002-09
    165
    Yeah...I know it may not get placed exactly but you can flip it using the flip handle to position it or use align tool to perfect the positioning.
    Xavier G Papuraj
    2005-08
    26
    Thanks for replies. Still not sure how i will actually make this family.
    I inserted individual windows and then placed openings to clean up the
    brickwork showing between the windows. Not what I wanted to do but
    it works for now.
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,439
    Its actually very easy. Create a generic model family, in plan create a curved extrusion for the glass, the use a sweep and pick the edges for the frame. Note set up your parameters for the curved extrusion first, ie radius, arc length etc. Now change the family type to a window family(note there is NO wall needed) Set the glass to glass, Frame to frame. Now load into a project. At the radius'd wall, use the opening tool to create the opening. Now make the radius parameters of the window family match the radius of your wall and put it in the opening.
    Scott D. Brown, AIA
    Project Coordinator | Director of Building Information Modeling
    HHCP.com
  1. Creating a curved window family
    By p.stewart in forum Revit Architecture - General
    Last Post: 2010-11-02, 03:01 PM
  2. window arrays in curved wall
    By Steve Jager in forum Revit Architecture - General
    Last Post: 2009-08-14, 03:40 PM
  3. how to make curved window with curved arch trim in curved wall
    By lcollot in forum Revit Architecture - Families
    Last Post: 2008-01-21, 01:46 PM
  4. Window/Door Assembly in curved wall
    By scompton in forum ACA General
    Last Post: 2007-07-04, 12:05 AM
  5. Trim around arch top window in curved wall
    By eamador in forum Revit Architecture - General
    Last Post: 2006-11-03, 02:30 PM
