Thread: Save Title Block drawing, and Insert it correctly into other drawing files
    2007-05
    6
    Default Save Title Block drawing, and Insert it correctly into other drawing files
    Hello, I have made a title block for my drawings, how can i save just the title block so i can place it in other dwg's using insert block and have it place in the right place automatically?
    Thanks a bunch
    Troy
    0,0,0 The Origin
    8,570
    Default Re: Save Title Block drawing, and Insert it correctly into other drawing files
    Make sure the lower left corner (or another point of your choosing) is at 0,0 then just save/close the file. Like any .dwg file, it can be inserted into any other open file.
    When you come to insert it, set the insertion point to 0,0,0, rotation = 0 and (most likely) scale to "specify on screen". That assumes you're working entirely in modelspace.
    Earth
    9,805
    Quote Originally Posted by t.benson
    Thanks a bunch
    Troy
    If you plan to use this TB all the time, open your template drawing and create the TB in a layout. Then whenever you start a new drawing, the TB will be there waiting on you.....
    R.K. McSwain | CAD Panacea |
  1. Replies: 16
    Last Post: 2015-07-20, 01:42 PM
  2. Drawing scale of base view in title block
    Last Post: 2013-12-02, 11:06 AM
  3. Block Insert - Right Click Block Open Drawing
    By Texan1 in forum ACA Wish List
    Last Post: 2011-11-26, 04:38 AM
  4. Update Title Block data in numerous drawing files
    By rer2003mcbs.66431 in forum AutoLISP
    Last Post: 2007-05-29, 01:58 PM
  5. Insert block definition from one drawing into current drawing
    By ktisdale.118609 in forum VBA/COM Interop
    Last Post: 2006-08-08, 10:28 PM
