Hello all.
Does anyone know of reasons that would cause some room in the schedule not to show the area? Please see attach. The rooms are on different level, but the area are all the same.
Hello all.
It looks like you are not scheduling each instance of your rooms (because of the Count field). Perhaps one or more of the rooms in the rows where the area is empty are not fully enclosed? Why don't you do a full instance schedule and see if you get more detailed information.
We are the music makers...we are the dreamers of dreams.
All Things BIM
Visit the Revit Community Home Page
We have done a full instance schedule and the areas show up. it is just when we ask Revit to not itemize every instance is when the areas do not show up. double check to make sure all areas are enclosed correctly...they are.Originally Posted by JamesVan
you need to get the column / field in the schedule to "calculate totals" it's in the options / formatting somewhere (don't have reivt running at the moment to check exactly where)
we do not want it to "calculate totals" (if i understand what it does). We want it to list how many occurrances there are of that room (the count) and what the Area is. not the "area"x"count"=total.Originally Posted by sonya
it work with other cases, just not all.
If i understand what youre after, it is only going to display a value for Area if every instance of that Area has the exact same Area Value.
I would expand the schedule to Itemize every instance and see if that is the case. If theyre off or different at all, they wont display properly.
The above post is by a user not frequenting the site. Questions regarding post:
Send to: aaron@aaronmaller.com (include text of post). Thanks.
We tested that yesterday. The Area were all the same. But I'll have my team mate double check.Originally Posted by twiceroadsfool
Im just throwing it out there, becuase with the multiple counts, and the not calculating totals, im pretty sure thats the only way they will display.
As far as that goes, maybe expand them to a couple of decimal places and make sure one isnt rounding different for some reason?
Check the properties of each room. You will see the area accuracy is two decimal places. Even though area in the schedule is rounding to the nearest sf it still considers the decimals when sorting. Chances are the area of each room is slightly off. One room may be 304.06 sf and the other is 304.05 sf for example.
It would be nice if there was a tolerance control for schedules that would give you the option to ignore the decimals.
DG
thanks to twiceroadsfool and dgraue for the suggestion. Y'all were correct. When we showed 3 decimal places, sure enough they were slightly off. now, is there a way to avoid doing an area plan for total square footage calculation for units(also avoid making the interior walls of the units non-room bounding)? is there a way to place a formula in the schedule or parameter so that Revit will add up the rooms that are assigned to a unit. meaning, in a unit we would like Revit to add:
Bath+closet+main room = total area of the unit
and to have the total area of the unit to show in the schedule.
i think the answer is no, but i am hoping i am wrong. again, thanks for all the help.
