Results 1 to 7 of 7
Thread: Prevent AutoCAD 2008 from opening multiple sessions when DWG's opened from Explorer
    100 Club Commissar Rod's Avatar
    2006-01
    Harrisburg, PA
    137
    Default Prevent AutoCAD 2008 from opening multiple sessions when DWG's opened from Explorer
    Maybe the title is self explanatory, but here's the problem
    I just got autocad 2008, and I prefer to open files from windows explorer instead of open in autocad. In my previous version of Autocad, 2007 LT, it would open all drawings in the same session. 2008 wants to open a new session each time. I went through The Autocad Help file, and i found mention of a system variable that should be set to 0, (the name escapes me) and it is.
    Any help would be GREATLY appreciated
    The opening sequence to "Saving Private Ryan" was based on a game of dodgeball Chuck Norris played in 6th grade
    0,0,0 The Origin
    8,027
    Default Re: Prevent AutoCAD 2008 from opening multiple sessions when DWG's opened from Explorer
    Try this (I'm working from memory here) -
    open a Win explorer window.
    pick the tabs - Folder Options and File Types.
    scroll to the DWG entry and pick Advanced.
    pick Open and Edit.
    make sure the Use DDE box is checked and that the DDE string is [open("%1")]
    I think that will fix it.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    100 Club r424andy's Avatar
    2006-01
    In this Chair
    170
    in 2007 it is single drawing interface...the check box under options in 2008 is not there but you can change it by typeing "sdi" and setting it to 0
    All AUGI, all the time madcadder's Avatar
    Back in the Bay; Looking for work.
    979
    Quote Originally Posted by jaberwok
    pick Open and Edit.
    My AutoCAD is set for MDI and my explorer is set the way listed above. I can confirm only one instance of AutoCAD.
    2006-01
    Harrisburg, PA
    137
    changing the setting for SDI does not seem to change anything at all.... i'm just starting to get the hang of it though, so maybe its not all that bad
    2002-05
    72
    Could it be you have TASKBAR turned on so it appears you have multiple sessions open when in fact it is only one?
    2006-01
    Harrisburg, PA
    137
    Each "version" in the taskbar will have different files showing and open
  1. ACAD Opening Multiple Sessions
    By tonyv in forum AutoCAD General
    Last Post: 2012-07-04, 07:41 PM
  2. Replies: 9
    Last Post: 2007-10-23, 05:30 PM
  3. Prevent AutoCAD Text Window from opening
    By PRSMAIL in forum AutoLISP
    Last Post: 2007-06-11, 12:32 PM
  4. AutoCAD LT 2008 prevent Drawing1 from being opened
    By rodo in forum AutoCAD LT - General
    Last Post: 2007-05-03, 01:16 PM
  5. Replies: 5
    Last Post: 2006-10-09, 09:25 PM
