Thread: Project coordinates not in synch with cad export
    2006-07
    26
    Default Project coordinates not in synch with cad export
    Our team is doing all of our project documentation in revit, but our consultants are using autocad. Recently, we needed to relocate the (0,0) origin point of the project. In revit, I've done the following commands: tools --> project position/orientation --> relocate this project. In revit, everything seems to read fine. I'm able to take a spot elevation from the new project origin and it reads as 0,0. The problem occurs when I export to AutoCAD - the 0,0 is still at the old origin point. I'm able to fix this by going into each AutoCAD file and correcting the world 0,0, but this is not an option when dealing with a set of 100+ drawings. I need the adjusted project origin in revit to read through to the AutoCAD backgrounds without having to make any adjustments in AutoCAD. Any suggestions?
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Default Re: Project coordinates not in synch with cad export
    When you export make sure you change the coordinate option in the export dialog from project internal to shared.
    Scott D. Brown, AIA
    BECK
  1. export line coordinates
    By spamkiller433238 in forum AutoLISP
    Last Post: 2020-04-21, 04:35 PM
  2. 2013: How do I export to IFC with project coordinates and not real world coordinates?
    By m.knutsson in forum Revit Architecture - General
    Last Post: 2013-10-15, 06:54 AM
  3. Project Coordinates, Shared Coordinates, and the new Survey Point
    By Wes Macaulay in forum Revit - Platform
    Last Post: 2012-07-05, 06:20 PM
  4. Export Coordinates
    By Maastricht in forum AutoCAD Map 3D - General
    Last Post: 2009-08-19, 04:45 PM
  5. Replies: 0
    Last Post: 2007-09-30, 02:56 PM
