Results 1 to 9 of 9
Thread: AutoCAD 2008 can't display Chinese fonts properly
    2006-11
    19
    Question AutoCAD 2008 can't display Chinese fonts properly
    When I opened the drawings with chinese fonts no problem can be displayed properly.
    But when I installed a AutoCAD2008 version,open it the chinese fonts can't be properly displayed.
    I noticed some of the drawing's code page is ANSI 1252, maybe it's the problem.
    But why AutoCAD2007 no problem?
    Any one can explain this?
    2001-03
    13,499
    Question Re: AutoCAD 2008 can't display Chinese fonts properly
    Hi
    Does AutoCAD 2008 have access to the font files it needs to successfully display the Chinese text characters?
    You may wish to have a browse through the following thread...
    ADT 2004 sees Chinese text as Multibyte codes
    Have a good one, Mike
    2001-03
    13,499
    Default Re: AutoCAD 2008 can't display Chinese fonts properly
    Hi
    Plus, you may wish to look at THIS post.
    2006-11
    19
    Hi All,
    Nice to received so many feedback...
    Yes,Mike I copied all the fonts from AutoCAD 2007 to AutoCAD 2008.
    The problem now is when I open it with AutoCAD 2007,no probelm at all,xref files with Chinese Fonts,the Chinese Fonts in the dwg file are all correctly displayed.
    But when I open it with 2008 instead,AutoCAD 2008 can't properly displayed the chinese fonts in xref files and direltly in the drawing,it needs dwg codepage transfer from ANSI 1252 to 936,then it is OK.
    I am running a WINXP PRO english version,and in fact the drawing with ANSI 1252 code page are
    created by AutoCAD 2002.
    So,I am wondering why...
    2001-03
    13,499
    Hi
    If possible please post an example drawing file (and associated files), so I (and others) may take a look at the drawing file in AutoCAD 2008.
    2006-11
    19
    Hi Mike,
    It is simple,the drawing containing ANSI 1252 code page are created with AutoCAD 2002.
    Open it with AutoCAD 2007 properly displayed the Chinese fonts but can't edit.
    Open it with AutoCAD 2008 can not properly displayed and can not be edited.
    After using dwg code page transfer both 2007/2008 can properly displayed and can be edit.
    I mean in text edit conditions,the Chinese fonts also properly displayed.
    But it's difficult between the relations between 2002/2007/2008.
    Why using 2007 properly displayed but 2008 can not...
    OK,I will upload the drawing tomorrow.
    2006-11
    19
    Smile Re: AutoCAD 2008 can't display Chinese fonts properly
    Hi,
    Here is the sample file.
    Thanks for helping me...
    2001-03
    13,499
    Quote Originally Posted by lvsuccess
    Hi
    Please post the associated files used in the drawing file eg Additional / Custom Font files (hz. hztxt, st, etc).
    2006-11
    19
    Here is the fonts...
  1. Exploding Chinese Font In AutoCAD 2008
    By lucasmerd896229 in forum AutoCAD General
    Last Post: 2011-02-22, 11:00 AM
  2. AutoCAD for Mac display fonts?
    By lorne.bourdo.152516 in forum AutoCAD for Mac General
    Last Post: 2010-10-27, 02:09 PM
  3. Fonts Missing in AutoCAD 2008
    By hgrigel in forum AutoCAD General
    Last Post: 2009-06-30, 04:37 PM
  4. How can I get Chinese Fonts?
    By headfire2222 in forum AutoCAD General
    Last Post: 2007-06-19, 07:18 PM
  5. SHX fonts show up hollow in AutoCAD 2008
    By tom.petray in forum AutoCAD General
    Last Post: 2007-04-25, 02:24 AM
