Thread: Family parameters in revit family
    2004-07
    179
    Question Family parameters in revit family
    Hello,
    I had a query regarding the family parameter in revit family.I have a carved head board of a bed, till i make the entire bed in the family using extrude and sweep command in solids its okay but when i go to change the parameter value in the family types it gives me errors and does not take the new parametric value ,it extends the head board unevenly without taking the centre pt into consideration.I have placed the labels taking my reference lines ,then also it is giving me errors.
    I'll be glad if anyone helps me out.
    Regards,
    Aliya
    Note: I have attached the bed drawing.
    2003-05
    5,153
    Default Re: Family parameters in revit family
    It sounds as though you need to add " EQ" contraints around the central reference plane.
    2004-07
    179
    I have added the equality constraints but still it does not help! Idon't know whats the problem?
    aliya
    2003-09
    1,907
    Which came first, the model or the reference planes? If the model, you will have to go back and move the model entities around to force a lock to the reference plane (always create your reference planes first).Then flex the reference plane, not the model. (Reference planes needed should be center, and each side, and I guess length head to foot if you need that on the bed).
    Okay - Opened your family and fooled with it a minute - Your dimesions should flex the reference planes, or objects that are locked with a set dimension string. Right now they
    are not locked together. The width variable should be associated with the two reference planes that you have made equal. Will work more on it later - Got to stop and go to work now-----
  1. 2013: Door Family Parameters Family vs. Project
    By jsteinhauer in forum Revit Architecture - Families
    Last Post: 2014-08-14, 02:56 PM
  2. Can you reference a nested family in the main family parameters?
    By CBroda in forum Revit Architecture - Families
    Last Post: 2010-06-29, 04:10 AM
  3. Replies: 7
    Last Post: 2010-03-28, 01:20 AM
  4. RA2008/N - Batch Create Family Parameters From Nested Family - O
    By atbergma in forum Revit Architecture - Wish List
    Last Post: 2007-07-11, 06:33 AM
  5. Family parameters in revit family
    By aliya14 in forum Revit Architecture - General
    Last Post: 2004-07-23, 05:15 AM
