Results 1 to 10 of 12
Thread: Place a Block at points along a Polyline
    2007-05
    38
    Default Place a Block at points along a Polyline
    Hello,
    I'm just taking my first steps in the autolisp world, so forgive me if I'm asking for something obvious.
    I'm trying to put blocks along a polyline (for example, let's take a rectangle 55x95) using autolisp. What I want the command to do is the following:
    1. select a (previously drawn) polyline (user input)
    2. place a block on every corner of that polyline
    3. Place the same blocks along every vertice of the polyline ( using 'divide'??) in a way that the distance between two blocks is never greater than 8.
    The result would then be a rectangular polyline, with blocks on every corner, 12 blocks along the long sides (every 7.91) and 7 blocks along the short sides (every 7.86).
    If someone could put me in the right direction, i would be very grateful.
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Default Re: Place a Block at points along a Polyline
    I wrote something that does something very similar. It was actually for Land Desktop, and was designed to place points at various offsets along polylines.
    The code is available here. The utility functions that perform this task are primarily in the VLUtil.lsp file, and the usage can be seen by looking at the PGRD.lsp file. Without Land Desktop, you can simply ignore all the Point stuff and all the stuff in the LDUtil.lsp file, and just concentrate on that stuff in VLUtil.lsp.
    All AUGI, all the time CAB2k's Avatar
    2016-01
    Brandon, Florida
    687
    wbreedveld
    A sample DWG goes a long way to convey your needs.
    Is the polyline the outside of the wall or center of the wall?
    Do you have a block you need to use or will any do?
    Are you working in Feet or Inches for Units?
    Why are the Long sides different from the short sides for spacing?
    Do you base your spacing on a clockwise or CCW direction? Or other?
    Are the blocks to be placed on a specific layer?
    Is the poly line on a specific layer?
    BTW
    Welcome to AUGI LISP
    2007-05
    38
    Quote Originally Posted by sinc
    I will look into it.
    thanks!
    2007-05
    38
    Quote Originally Posted by CAB2k
    wbreedveld
    done see attatchment
    that doesn't matter. It is just a single line, no wall
    block name = "paal"
    nope, metric 1:1
    That's because the maximum distance between two blocks is 8, and the blocks have to be divided along a line \. Different linelenghts -> different spacings between blocks.
    that does not matter, i think?
    would be nie. in the example, they are placed in layer "block"
    yes, in the example it's in layer "polyline"
    BTW
    thanks
    2016-01
    Brandon, Florida
    687
    The DWG helped, thanks.
    Here is an example.
    ;;  CAB  05.22.07
    ;;  Divide a dividable object based on segment length
    ;;  and max dist between blocks to be inserted
    ;;    -=<  NO ERROR CHECKING  >=-
    (defun c:DivideSegments () (c:DS))
    (defun c:DS (/ CNT DIST ENDPAR ENT IDX LEN MSTEP START STEP clay)
      (vl-load-com)
      (setq clay (getvar "clayer"))
      (if (and (setq ent (entsel "\nSelect object to divide."))
               (not (vl-catch-all-error-p
                      (setq start (vl-catch-all-apply
                                    'vlax-curve-getpointatparam
                                    (list (car ent) 0.0))))))
        (progn
          (command "._Undo" "_begin")
          (setvar "clayer" "block")  ; Block Layer
          (setq ent (car ent))
          (setq mStep 8)
          (setq endpar (vlax-curve-getendparam ent))
          (setq idx 0)
          (while (<= (setq idx (1+ idx)) endpar)
            (setq len (- (vlax-curve-getdistatparam ent idx)
                         (vlax-curve-getdistatparam ent (1- idx))))
            (setq step (/ len (fix (+ (/ len mstep) 0.99))))
            (setq cnt (fix (+ (/ len step) 0.99)))
            (setq dist (+ step (vlax-curve-getdistatparam ent (1- idx))))
            (repeat cnt
              (command "-insert" "paal" "_non" (vlax-curve-getpointatdist ent dist) "1" "" "")
              (setq dist (+ dist step))
          (setvar "clayer" clay)
          (command "._Undo" "_end")
        (prompt "\n***   ERROR - Can not divide that object.  ***")
      (princ)
    <edit: revised code>
    2007-05
    38
    Here is an example.
    That works like a charm!
    I cannot thank you enough This wil save me soooo many hours a month calculating distances and copying blocks.
    Now i can spend the rest of my evening figuring out what the routine is actually doing
    2016-01
    Brandon, Florida
    687
    Glad it worked for you.
    There is room for improvement in the lisp but it gets the job done.
    I'm sure the one from sinc would also work with some mods. He is a smart guy.
    2007-05
    38
    I will certainly look into that one as well, but your routine looks a bit easier to understand for me, since I'm just a beginner is LISP. Tonight I'm going to figure out what all the variables are actually doing
    thanks again, both of you, for helping me out.!
    2007-05
    38
    already making modifications
    Some of the polylines used are open, come are closed. I would also like a block to be at the beginning of an "open" polyline, but doing so for a closed polyline would create a "double" block at the start (=end) point of the polyline.
    Reading the lisp manual I stumbled upon "vlax-curve-isClosed", which checks if a given entity is closed. The code now looks like this (also changed layernames and mStep to my specific needs):
    ;;  CAB  05.22.07
      (vl-load-com)
        (progn
          (setvar "clayer" "staalkabel")  ; Block Layer
          (setq mStep 8000)
          (setq idx 0)
    	; avoid double blocks on closed polylines
    	(if (vlax-curve-isClosed ent) ; check if polyline is closed
    	  () ;if polyline is closed, do nothing
    	  (command "-insert" "paal" "_non" (vlax-curve-getpointatdist ent 0) "1" "" "") ;if polyline is open, insert block at beginning of polyline
    	) ;end if
    	(repeat cnt
            ) ;end repeat
          ) ; end while
      ) ; end if
      (princ)
    <edit: typo's>
  1. 2013: DRAWING A POLYLINE THAT ATTACHES BLOCK AT POINTS
    By CIngalsb397420 in forum AutoCAD General
    Last Post: 2013-07-08, 01:09 PM
  2. Replies: 0
    Last Post: 2011-10-11, 08:38 AM
  3. Replies: 2
    Last Post: 2007-03-28, 11:12 AM
