Thread: alias issues
    2006-12
    4
    Default alias issues
    a coworker of mine is using LDD2004 and can't get his aliases to work. Replacing his pgp file and running the REINIT command does not fix it. Aliasedit command brings up an empty window (no aliases available).
    The REINIT command brings up an error message that says "dialogs are not available because DCL files are not loaded".
    The install is a new install and the aliases have never worked. I'm thinking that LDD needs to be reloaded, perhaps something happened during the install process.
    wondering if anyone else has had a similar problem.
    thanks
    -dennis
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Default Re: alias issues
    You might want to check the Support path on OPTIONS and make sure it looks OK. It should contain the directory that holds your PGP file, as well as the ACAD.DCL and BASE.DCL files.
    Usually, this directory is in your user's home directory, in Application Data/...<version>.../enu/Support.
  1. alias autostudio
    By leoreds1995694414 in forum Italiano - Altri software Autodesk
    Last Post: 2015-03-12, 10:40 PM
  2. Column alias
    By mightymid9 in forum VBA/COM Interop
    Last Post: 2009-09-23, 07:08 PM
  3. 3DS Max or Alias Maya?
    By CADBIMManager in forum DV - The 3rd Dimension
    Last Post: 2005-12-06, 09:28 PM
  4. Alias Editor
    By justin.d.ehart in forum AutoCAD General
    Last Post: 2004-11-18, 04:23 PM
