Thread: Add Objects to an existing Block
    2004-07
    Detroit Michigan
    2,508
    Default Add Objects to an existing Block
    How can I add more objects to a block?
    I forgot to use block editor.
    How can I some existing linework to a predefined block?
    My only idea:
    Explode the block, purge the drawing, recreate the block.
    I get asked to redefine the block, however, I cannot resave the block as
    it still exists elsewhere in the drawing.
    I couldn't find anything in the help menu. I was looking under "redefine".
    All AUGI, all the time gfreddog's Avatar
    2003-07
    Pequannock NJ US of A
    641
    Default Re: Add Objects to an existing Block
    I usually use the old REFEDIT command.
    You'll see the other lines that are not in the block that you can select and use the ADD button in the Refedit Toolbar to add them to the block.
    I think that's what you're looking for
    2004-07
    Detroit Michigan
    2,508
    Talking Re: Add Objects to an existing Block
    That works like a charm. Thanks.
    9,803
    Quote Originally Posted by Robert.Hall
    My only idea:
    I see that you were able to use REFEDIT, but after reading your post, I'm a bit confused.
    1. You can use BEDIT at any time. Not just to create a block
    2. You don't have to purge a block to redefine it.
    3. Your [explode, redefine] steps were correct, but you should have just been prompted to redefine the block after you use the ._BLOCK command and supply the same name. It doesn't matter that there are existing insertions of that same block.
    2004-07
    Detroit Michigan
    2,508
    Quote Originally Posted by rkmcswain
    I tried the block command, select the block name, reselect the desired objects, and
    get the following error:
    Block name references itself.
    I would have to erase all instances of the block within the drawing and then purge the drawing.
    All I wish to do is add some additional linework to the block that I had drawn in
    without using the block editor. Is it possible?
    9,803
    Lightbulb Re: Add Objects to an existing Block
    The only time I have seen that is when you try to insert a drawing that contains a block with the same name as the drawing.
    For example, create a new empty drawing. Create a block named "bay". Save this drawing as "bay.dwg". Now open another new empty drawing and try to insert "bay.dwg".
    See also: http://usa.autodesk.com/getdoc/id=TS66364
    That defeats the whole purpose of being able to update existing blocks... Strange... Any chance you can post this DWG file?
  1. Insert a new block using data from existing block
    By mike.43789 in forum AutoLISP
    Last Post: 2015-01-12, 11:50 PM
  2. Replies: 6
    Last Post: 2012-08-15, 04:55 PM
  3. Replies: 2
    Last Post: 2012-06-06, 12:28 PM
  4. Replies: 7
    Last Post: 2009-06-11, 04:52 AM
  5. Existing Block does not update when new Block is inserted
    By Rachel Ritchie in forum AutoCAD General
    Last Post: 2005-12-05, 03:04 PM
