Thread: Metal stud at the end of the wall as well as repeat every 16"
    2007-05
    8
    Question Metal stud at the end of the wall as well as repeat every 16"
    Is there a way to have the Metal stud at the end of the wall as well as repeat every 16"?
    Refer to attached dynamic block.
    One can stretch the wall and the stud will repeat every 16" but I am unable to have a stud at the end of a wall that is not divisible by 16. I would like to have the stud 16" O/C with the capability of a custom fit length of less that 16" at one end.
    Any help would be greatly appreciated.
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Default Re: Metal stud at the end of the wall as well as repeat every 16"
    Quote Originally Posted by spddesigns
    check out my ACT block for ideas on how to do that. what you are going to want to do is have your studs at each end stay at the end, but you'll have the intermediate studs array.
    S&D DB Sharing Forum
  1. Metal Stud Wall
    By andyhoman1550505 in forum Revit Structure - Families
    Last Post: 2012-04-24, 07:26 PM
  2. Light Gage Metal Stud
    By Thomas Maleski in forum Revit Structure - Families
    Last Post: 2010-11-30, 12:28 AM
  3. Metal stud DB rotate issue
    By beardking in forum Dynamic Blocks - Technical
    Last Post: 2010-06-08, 05:59 PM
  4. Metal studs/Woods stud layout Tools
    By pugander in forum Revit Structure - Wish List
    Last Post: 2009-09-18, 12:03 AM
  5. 6" Metal Stud Wall @ 16" o.c.
    By aokane in forum Revit Structure - General
    Last Post: 2006-03-08, 04:21 PM
