Results 1 to 10 of 11
Thread: Trees in Shaded with Edges View?
    2006-04
    Baltimore, MD
    380
    Default Trees in Shaded with Edges View?
    Is it possible to have trees in a 3D Shaded with Edges View? If so, any suggestions on where to find a family? (I've already checked out RevitCity).
    Thanks!
    2005-09
    Perth Australia
    470
    Default Re: Trees in Shaded with Edges View?
    You can import sketch up trees for this. The do work a little better with edges off as they end up a little bit black otherwise.
    You can also make lollipop type trees if you like.
    If you search in google sketch up trees you will find an entry under google warehouse sketchup. Have a look in there if you like.
    Rob
    I could stop if I wanted to whittendesigns's Avatar
    2004-07
    330
    I have uploaded 2 trees myself at RevitCity. One I just did the other day. They both show up in Shaded with Edges.
    All AUGI, all the time Arnel Aguel's Avatar
    2003-05
    Philippines
    577
    Here is one originally comes from Scott Brown and slightly modified to have nice plan representation.
    2010-08
    Hey Guys. Been trying to get the work around on this.
    I am trying to do the following.
    - 2D tree in plan and elevations for 2d graphical purposes as the RPC trees are pretty naff graphically.
    - In 3D views use the pre built standard revit RPC's
    So I would like to acheive the following a tree that caters for all situations 2D and 3D. What I would also like to do is create a tree that when i change the 3d parameters i.e change from a 3 m tall tree the 2d graphics also parametrically scale also.
    I have had an attempt at modifing the standard RPC families, trying to create the 2d? elements as masks and symbolic lines and also have tried an extruded solid with no joy of adding parameters. Any ideas?
    Oh also Ive tried linking other families into the master RPC with no luck.
    Any suggestions or successful attempts would be amazing
    2004-06
    Memphis TN area
    7,048
    Quote Originally Posted by patrick.broggan.258867 View Post
    I would love to have something like this, as well. I took the tree posted above from Scott Brown some years ago, and in Family Categories and Parameters changed Render Appearance Source from Family Geometry to Third Party. Doing this makes an RPC tree appear in with the imported DWG 2D symbols. Then I made that RPC tree visible only in 3D.
    The graphics works in a project (only the 2D symbols show in plan/elevation, and only the 3D RPC shows in 3D and rendered views), but like you said, there's no way to make the symbols scale appropriately with the tree height.
    Each symbol does have an Instance Scale parameter in the family, but it appears there is no way to access that parameter in order to make it a function of the height parameter.
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Note if you nest a symbol into the planting family, it will scale with the height.
    Scott D. Brown, AIA
    BECK
    2004-06
    Memphis TN area
    7,048
    So that means the plan and elevation representations need to be created as symbols instead of straight DWG imports?
    If only there were a way to get those DWG's out of that "nice tree" family...
    2004-06
    Memphis TN area
    7,048
    Quote Originally Posted by sbrown View Post
    Scott, I'm still stuck trying to figure out if it's possible to get the DWG symbol representations in that "Nice Tree" RFA to scale with the height setting of the tree family. I exported the plan view out to DWG and isolated the plan view symbol only, saved it as a new DWG, and imported that into a Generic Annotation family template, and nested that into a Planting family template.
    The symbol of course maintains it's real paper dimensions regardless of the drawing scale. I'm still not sure how it can be made to scale with the plant's height parameter. Any clues?
    All AUGI, all the time Alex Page's Avatar
    2004-03
    Wellington, New Zealand
    822
    It needs to be in a "Planting" family nested into a "Planting" Family
    Its as simple as that - Have a look at my example
  1. 2014: Shaded With Edges display
    By marduk.kurios679215 in forum Inventor - General
    Last Post: 2014-09-01, 01:26 AM
  2. 2012: Sun Settings - Shaded With Edges
    By Jrobker in forum Revit MEP - General
    Last Post: 2013-02-08, 03:46 AM
  3. View option? Shaded with Edges
    By katysue in forum Revit - Platform
    Last Post: 2008-08-25, 11:55 PM
  4. Shaded with Edges Montaged into Photograph
    By lhanyok in forum Revit - Rendering
    Last Post: 2007-07-10, 12:18 AM
  5. Panoramic Shaded with Edges
    By sfaust in forum Revit Architecture - Wish List
    Last Post: 2005-02-03, 09:17 PM
