Hi,
I'm trying to create a cavity wall type that will have concrete block for the footing, and brick on top. I know that we can do this using the stack wall, but I don't like stack wall so I I'm trying to do is to use the split region command to split a regular wall into different layers.
So my question is; is it possible to set different thickness for different layer? I guess it would be easier to understand if you take a look at the attached picture. Is it possible to delete the red portion in the picture?
Thanks in advance!
