Results 1 to 10 of 10
Thread: Google Earth Extension now available for AutoCAD 2008-based products
    AutoCAD Product Manager eric.stover's Avatar
    2001-02
    San Rafael, CA
    35
    Default Google Earth Extension now available for AutoCAD 2008-based products
    AUGI Membership,
    We wanted to announce that our Google Earth™ Extension for AutoCAD 2008, AutoCAD Architectural 2008, and AutoCAD Civil 3D 2008 is now available for beta testing on the Autodesk Labs website.
    This is a public beta (no non-disclosure is required) and we would appreciate your valuable feedback while you explore this new application!
    This publishing tool is designed to specifically meet the needs of Architects, Designers, and Engineers using Autodesk products. Using the easy-to-use, wizard-driven interface, you can publish your 3D models directly from AutoCAD into Google Earth™.
    From the planning process all the way through to public approval, everyone involved in your project can now view and navigate your projects in the context of the rich, interactive Google Earth™ environment. Other benefits include:
    • Deliver high-impact presentations at planning board meetings or public hearings
    • Streamline the preliminary project planning process
    • Share conceptual plans with your clients as they develop
    • Connect everyone involved in your project from the planning stage through to public approval
    You can find this extension on Autodesk Labs: http://labs.autodesk.com
    You can obtain a copy of Google Earth™ here: http://earth.google.com/
    -Eric
    2007-05
    38
    Default Re: Google Earth Extension now available for AutoCAD 2008-based products
    The image will be black and white – a current limitation imposed by Google Earth.
    erhm.. why is that?
    Anyone can make already make a screenshot from google earth and import that image in autocad in full color?
    The image-import works perfectly (AutoCAD 2008 over here) , but like this, it's like watching tv from the 60's.
    2001-02
    San Rafael, CA
    35
    They limit their API to B&W export for non-Google software applications. One workaround until this changes is to use Google Earth Save>image command and then drape the color image onto the 3D mesh as mentioned in the User's Guide. Not the easiest or obivous, but it does work.
    If you just copy/paste the image, you'll lose all of the coordinate information from GE.
    -Eric
    I could stop if I wanted to ekubaskie's Avatar
    2001-12
    Anchorage, Alaska
    324
    Quote Originally Posted by eric.stover
    -Eric
    I can see it with standard & plus, because you aren't supposed to use the imagery for commercial purposes anyway, but they really shouldn't do that if we're paying for GE Pro.
    100 Club aharris's Avatar
    2003-08
    Lubbock, TX
    106
    AUGI Membership,
    Why isn't this product available for MAP 3D? Wouldn't it make since to make is not only for Civil but also for Map?
    2006-05
    New Jersey
    147
    Any chance this will become 64-Bit compatible soon?
    2001-02
    San Rafael, CA
    35
    There won't be any special port of hte Extension to 64-bit this year. But we are examining the possibilites and costs of integration into our CAD applications in the future - this would include our 64-bit products.
    -Eric
    2005-06
    14
    I recently installed the Google Earth Extension for AutoCAD 2008. The installation seemingly went ok with no error messages.
    The product did not install into AutoCAD though. The commands, like PUBLISHKML are not recognized.
    I initially installed the extension beta and then Google Earth with no luck. I then uninstalled and reinstalled the extension beta, still no progress.
    I am looged into Windows XP as an 'Administrator.'
    I am running AutoCAD 2008 EDUCATION VERSION.
    Any troubleshooting tips?
    2008-10
    45
    We will use google earth to get roofs of buildings and do a basic area to get an estimate of roof sizes. So my question is, does this work for 2D or is it only for 3D objects?
    Thanks.
    2005-06
    14
    Lightbulb Re: Google Earth Extension now available for AutoCAD 2008-based products
    I had the opportunity to view a web application by a company called Pictometry. Their product uses oblique aerial photos which you can measure and overlay images on. They are the same images found on BingMaps.com
    I saw a demo where they not only measure the area, but the slope and height too.
    It's not free. Not sure if there are other applications that do the same.
    The web address is:
    http://www.pictometry.com/commercial/construction.shtml
  1. 2011: Civil 3D 2011 google earth extension
    By iwassum in forum AutoCAD Civil 3D - General
    Last Post: 2012-12-24, 07:37 AM
  2. 2012: Extension Google Earth - problème d'échelle
    By Olivier Malcurat in forum Revit Architecture - General
    Last Post: 2011-10-03, 07:29 PM
  3. google earth connection - globe link vs google earth extension
    By rpict in forum Revit Architecture - General
    Last Post: 2010-06-21, 03:27 PM
  4. Google Earth extension for AutoCAD 2009
    By rmk in forum AutoCAD General
    Last Post: 2008-03-31, 03:21 PM
  5. Beta of Google Earth Extension now available
    By eric.stover in forum AutoCAD General
    Last Post: 2006-06-29, 03:42 PM
