Thread: Pattern a Compnent arround an ellipse
    2004-12
    126
    Default Pattern a Compnent arround an ellipse
    I need to build an assembly that has an ellipsoidal shell with some equally spaced internal spines that are tangental to the ellipse, as shown in the attached screenshot. This took me about 45 seconds to do in Autocad. The supports must be separate parts, not Inventor "rib" features - I need to count them in a BOM. I discovered that I could create a "rectangular" pattern of workpoint features around the inside edge of the ellipse, but when I return to the assembly environment and then try to select this pattern as the basis for patterning my rib components, I can't select it. Any suggestions out there?
    Thank you,
    Manufacturing Moderator jonathan.landeros's Avatar
    2005-03
    Los Angeles County, Ca.
    440
    Default Re: Pattern a Compnent arround an ellipse
    Quote Originally Posted by Mike Y
    Thank you,
    It's not the 'perfect' solution, but you could use a sketch (in the ellipse shaped part) with work points to assemble the ribs in the right place.
    Another thought (depending on how you need to assemble it) is to orient things around the origin planes. It might be another way to quickly assemble things in the right place.
    Jonathan Landeros
    KETIV Technologies
    Orange County, California.
    I've got a blog: www.inventor-tales.blogspot.com
    “We have now left Reason and Sanity Junction.Next stop, Looneyville.” -Bob the Skull in the Dresden Files
    I could stop if I wanted to Ron Oldenbeuving's Avatar
    2004-06
    Lewiston, South Australia
    291
    See this post http://forums.augi.com/showthread.ph...012#post570012 on creating perpendiculer workplanes around a spline. It works for ellipses also, and you can then constrain to the workplanes.
  1. 2015: work arround families 3d and 2d
    By Menno de Vries in forum Revit MEP - Families
    Last Post: 2015-01-31, 10:54 PM
  2. Ellipse - Offseted as Ellipse, not as a spline.
    By harilalmn in forum VBA/COM Interop
    Last Post: 2009-06-09, 03:34 PM
  3. Angled parking arround a curve
    By ewhite in forum AutoCAD Civil 3D - General
    Last Post: 2008-10-18, 02:59 AM
  4. Detail Compnent Manager Layer name question
    By jasontirone in forum ACA General
    Last Post: 2005-07-08, 01:52 PM
