Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Formula Tricks
  1. #11
    All AUGI, all the time clog boy's Avatar
    2006-12
    Probably near a PC.
    843
    Default Re: Formula Tricks
    I learned a very neat trick yesterday. You ever get 'inconsistent units' as result from a formula? For instance if you wanted to multiply moolah with area with integer with bingzoombang? There's one real obvious way to make everything unitless.
    Example: =(Cost/1$)*(Area/1m²)*(bingzoombang/1bzb)
    Or in other words, just divide the parameter with one instance of it's own unit. The order in which you process everything will make a difference too, but if you really hit this one snag and don't have time or a superbly overflowing know-how to solve it 'the right way', make it unitless and you'll get the right result every darn time.
    1320mm/1mm = 1320. 8ft/1ft = 8. 1320 sq.ft/1sq.ft = 1320. $1,836,249/$1 = 1,836,249. Easy like that. It's not even a workaround, it's the right mathematical way to go around with processing numbers.
    Now suppose you have a formula and only want one parameter to be interactive. Height = Length / 2 will make both interactive.
    You can add a dummy parameter, but that's just clutter. My way: Height = if(Length>0, Length/2, 0)
  2. #12
    AUGI Addict truevis's Avatar
    2004-07
    Massachusetts, USA
    1,191
    This does what a lookup table does (without requiring RME):
    Tap Thickness = if(Tap Diameter < 0' 1 1/4", 0' 1 1/16", if(Tap Diameter < 0' 2", 0' 1 5/16", if(Tap Diameter < 0' 2 1/2", 0' 1 5/8", if(Tap Diameter < 0' 3", 0' 1 5/8", if(Tap Diameter < 0' 3 1/2", 0' 1 3/4", if(Tap Diameter < 0' 5", 0' 2 1/4", 0' 3 11/16"))))))
  3. #13
    2009-07
    108
    Please help me de-bug my formula. IF ( H_LEFT > H_RIGHT ) H_LEFT , H_RIGHT ) and I am getting a "VERIaBLE NOT EXPECTED" error. I have two fields with lengths in them and i want to do a calculated formula in my scedule that says whichever of the two is the higher value than put it in this new cell. I can write it in excel but it's now working right in Revit.
    Thanks!
  4. #14
    All AUGI, all the time CADastrophe's Avatar
    2012-01
    Site of the next CADaclysm
    813
    The only issue with this is that the IF statement is closed after the conditional statement, which would produce an error. That first closed parenthesis should simply be a comma, instead.
    IF ( H_LEFT > H_RIGHT , H_LEFT , H_RIGHT )
  1. 2013: How to use this Formula,"Formula That Returns Strings"?
    By mike99 in forum Revit Architecture - General
    Last Post: 2013-01-09, 06:28 AM
  2. Tips und Tricks ?
    By homer_312 in forum Inventor - General
    Last Post: 2008-05-31, 01:40 PM
  3. Any Tip / Tricks Out there?
    By BCrouse in forum AutoCAD Tips & Tricks
    Last Post: 2007-04-19, 07:10 PM
