can anybody tell me how to recover a drawing file if Recover command couldn't make it?
When i use the recover command i get an Autocad message : "Unable to recover drawing file"
Regards
Hi there,
This is the method I use when the actual drawing file is corrupted. At the very bottom of the "Tools" pull-down menu, click on "Options" This will indicate where the temporary drawing files are store. If you've been using Autosave, then there should be some files with the .sv$ file extension kicking around in this folder.
Next using Explorer I locate an .sv$ file which was created before you started having problems with the drawing file. Rename this to a .dwg file extension, then open it with AutoCAD. Hopeful you will have something usable, that will save you drawing the whole thing from scratch.
Dessinateur projeteur indépendant
Architecture Suite 2013, AutoCAD LT 2013
Typical Padawan.
Visit the French forum
is it possible that it is a drawing that is of a newer format than your current version of AutoCAD?
Christopher T. Cowgill, P.E.WIGHTMAN & ASSOCIATES, INC.
ENGINEERING <> SURVEYING <> ARCHITECTURE
AutoDesk Infrastructure Design Suite Premium 2013 x64
Windows 7 Pro x64
Try another PC. Sometimes another user is able to get the file to recover.
Just to clarify...Originally Posted by L'irlandais
A) Autosave files are not necessarily saved in the same directory as AutoCAD temporary files. The sysvar SAVEFILEPATH holds the autosave directory.
B) Autosave files (.SV$) are deleted when AutoCAD successfully closes, so there won't be one there unless AutoCAD last crashed. There may be a good autosave BAK file there though.
See this link for some ideas.Originally Posted by a_meteni
Note the last link on that page -> if nothing else works, send the drawing to Autodesk.
I would start with the BAK file for that drawing. If the BAK is not corrupt and you save often it should not take you long to redo the work in the drawing.
I have had success opening or recovering a drawing in a higher version of AutoCAD. If you have 2008 install it and try to recover it there.
Jeff Paulsen
FWIW, IntelliCAD can sometimes (quite often) open files that AutoCAD can't.
John B
"With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
1.Your drawing is made in your version of AutoCAD?Originally Posted by a_meteni
2.It is difficulty to recover it because it can be corrupted and you can't do anything and follow idea of L'irlandais.
Another method which I usually attempt before looking for .bak files is to open a blank drawing and insert the corrupt one into it as a block. This often works and it is then a simple case of exploding the block, running the Audit command and saving the drawing.
Failing this, as others have said, try opening the drawing on another PC or try to open it with any other program capable of opening a dwg file.
