Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
Thread: Recover a drawing file when the Recover command fails
  1. #11
    I could stop if I wanted to SRBalliet's Avatar
    2004-06
    In a loghouse, Looking for a job!
    495
    Default Re: Recover a drawing file when the Recover command fails
    Quote Originally Posted by jaberwok
    FWIW, IntelliCAD can sometimes (quite often) open files that AutoCAD can't.
    Microstation too. (As much as I hate Microstation)
    Steve Balliet
    Craig Co., VA
    Civil 3D & Land Desktop 2008, Mechanical 2009
  2. #12
    Active Member a_meteni's Avatar
    2002-12
    Cairo
    52
    lately i discovered that these dwg files are restored form a crashed laptop using windows vista. -my PC runs XP professional & auto cad 2007- and its not only dwg files but also all other file extensions. so i think my last hope is to try to open the files on a different operating system instead of xp
    Regards
  3. #13
    Modérateur Forum Français CGM's Avatar
    2005-10
    France - 68
    759
    Thumbs up Re: Recover a drawing file when the Recover command fails
    Quote Originally Posted by a_meteni
    Good luck with it,
    Please do keep us posted.
    Dessinateur projeteur indépendant
    Architecture Suite 2013, AutoCAD LT 2013
    Typical Padawan.
    Visit the French forum
  4. #14
    2006-07
    Phoenix
    32
    Is a bak file created during an autosave or only when a full save or qsave is done?
  5. #15
    Houston
    7,520
    Quote Originally Posted by kevinc.117928
    If "create BAK" is enabled, both.
  6. #16
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    1,901
    I don't think BAK files are created during an autosave.
    Jeff Paulsen
  7. #17
    Houston
    7,520
    Exclamation Re: Recover a drawing file when the Recover command fails
    Quote Originally Posted by jpaulsen
    They are.....
  8. #18
    All AUGI, all the time CADDmanVA's Avatar
    2006-12
    New Orleans, LA
    881
    Maybe not, depends on whether or not the BAK functionality is turned on. I personally don't trust BAK files any more. For a couple years now, I've caught BAK files which are several saves behind the current version of the file.
    I loved the NCS so much, I joined the committee!
    "Truth suffers from too much analysis"
    I remember AutoCAD R10
    When will Autodesk port AutoCAD to Linux?
  9. #19
    Houston
    7,520
    Quote Originally Posted by CADDmanVA
    That is why I said "If 'create BAK' is enabled" when initially responding to the question.
    A BAK file from a .DWG or a .SV$?
    Consider what AutoCAD does during a QSAVE (assuming "create BAK" is enabled)
    1. It writes the contents of the editor to a temp file.
    2. It renames the current drawing from .DWG to .BAK
    3. It renames the temp file to the correct file name with a .DWG extension.
    I don't see how you have had problems with BAK files since it's simply a copy of your last save. In fact, if you QSAVE twice in a row, then your BAK = the DWG.
  10. #20
    2006-12
    New Orleans, LA
    881
    Quote Originally Posted by rkmcswain
    Sorry about the enabled part, I somehow looked over your original post, my bad.
    I understand the process AutoCAD writes its save files and temp files. It has just been my experience recently that even though I QSAVE every 15 minutes, the BAK file is usually four or more saves behind. The autosave files (SV$) tend to do me justice in most cases though.
  1. Unable to recover this drawing
    By WhataMaroon in forum AutoCAD General
    Last Post: 2010-10-26, 07:44 AM
  2. Recover a Drawing File
    By rhayes.99001 in forum ACA General
    Last Post: 2007-06-29, 06:38 PM
  3. Cannot Recover drawing - AutoCAD 2005 file
    By CADKitty in forum AutoCAD General
    Last Post: 2006-10-03, 01:57 PM
  4. Recover & _recover are not the same command
    By Aquaserpent in forum Land Desktop - General
    Last Post: 2005-02-03, 02:45 PM
