I'm creating a parametric window family for louvres.
The number of louvres in the height changes with a parametric array and works fine, but I'm having problems flexing the width.
The louvres are an extrusion, with the bottom louvre having its edges align locked to reference planes at the frame edges. This bottom louvre then is arrayed vertically, with a formula changing the number of louvres with the height.
When arrayed, the other louvres created, are not locked to the edge reference planes for some reason, so the width of the array does not flex properly.
Once I get this working, I will probably replace the louvres with a nested family. Also I'll then post to RUGI if anyone is interested.
The family is attached, if anyone can help.
beegee
