It's second day I've been trying to solve a problem with rendering of polylines in Autocad 2008, problem that I didn't have at all in Autocad 2006. Read a dozen of topics on Autocad. Can't work further on
The problem is that a flat polyline with length width and thikness parameters (looks as a box) renderes smooth in the corners (looks as a cylinder, or a box with fillets). I need it to render flat as it is! And by some reasons I cannot use solid which render correctly, I need polyline! In Autocad 2006 in render menu there is option "smoothing angle" that just for the such case. 45 degrees by default will do pretty good. But what shell I do in Autocad 2008? There is no such option! It renderes smoothed!
There was a topic on this metter here http://forums.augi.com/showthread.php?t=52371 called "RENDER pline with thickness causes wrong result from 2006 to 2007" but it hasn't been solved.
