Results 1 to 6 of 6
Thread: Dynamic Block Section Cut Mark not behaving when rotated
    2001-10
    135
    Red face Dynamic Block Section Cut Mark not behaving when rotated
    I am trying to create a dynamic section cut block and I'm running into an issue. The functions all work right until I use the rotate feature. Once I rotate the arrow and tail, the stretch feature on the tail does not work properly. Any suggestions? I've attached the block so someone can hopefully see what I'm referring to. The tail currently has a linear parameter & action associated with it.
    Regards,
    Marc
    AUGI Addict .chad's Avatar
    2006-04
    is it lunch time yet?
    1,124
    Default Re: Dynamic Block Section Cut Mark not behaving when rotated
    1st - check the DB forum (im sure a friendly mod will move it for you)
    2nd - instead of selecting the stretch action with your rotate paramater, select the distance paramater.
    3rd - i would recomend locking your attributes - this will prevent moving them errantly, and you will have a few less grips visible while the block is selected. makes it easier on the eyes.
    This aggression will not stand. Man.
    2001-10
    135
    Sweet!! That worked like a charm Thanks. I also locked my attributes (seamingly) but nothing changes. I can still move them by selecting the grips that still show up? Am I missing something here?
    2006-04
    1,124
    Quote Originally Posted by mboyer
    use battman or attsync to sync your attributes.
    2001-10
    135
    Thanks, I realized that was the issue after I sent the last message....Da.herrr!!!
    2006-04
    1,124
    glad its all working.
  1. Looking for dynamic grid bubble block that can be rotated & jogged
    By oompa_l in forum Dynamic Blocks - Sharing
    Last Post: 2011-10-27, 06:17 PM
  2. Dynamic section mark
    By kmusser in forum Dynamic Blocks - Technical
    Last Post: 2009-10-15, 07:51 PM
  3. Dynamic Section Mark
    By dkennard in forum AutoCAD Customization
    Last Post: 2008-04-10, 02:43 AM
  4. Attributes not behaving themselves in Dynamic Block section indicator
    By kwong in forum Dynamic Blocks - Technical
    Last Post: 2006-12-22, 01:57 PM
  5. Point Parameter goes wacky if tag in Dynamic Block is rotated
    By mboyer in forum Dynamic Blocks - Technical
    Last Post: 2006-10-24, 11:59 AM
