pragati_khond
What is the most efficient way to rebuild manufacturer products like water closets or faucets as revit solids which are very curvy? We spent a lot of time getting close to the geometry but it does not match the curves of the actual product. I checked out lot of similar families online but to only find that they are all imported dwg files saved as revit families but not actual revit solids. Can these extremely curved shapes be achieved in revit or is importing a dwg the better way to get accurate with these shapes?
I know that you have an advantage in RVTs when you are using massing models to do complex walls, floors, etc. But you don't have those tools in RFAs. So at what point do you say that that is not something that Revit will realistically model and we have to find an alternate way?
Attached are some images of products that may not be impossible but hopefully illustrate the difficulty. I would appreciate your opinions on this. Thank you.
