Thread: Revit 2008 Rendering
    2007-03
    23
    Default Revit 2008 Rendering
    I use rendering quite a lot as a checking tool and I've found that with 2008, it's quite quirky. My previous version used to read that it went to 100% in the render process, in 2008, quite often it only goes to 50%, yet still does the full render. Probably at least 50% of the time when I go to Cancel the render (because I've already seen a mistake and don't want to go through the whole render process), render goes into freeze mode and sits still for ages. The Cancel button disappears and initially when it was frozen for such a long time, the only thing I could do was shut down Revit and start again as no buttons were operative. This often meant lost settings if I hadn't done a save immediately before starting rendering. It also meant a lot of lost time and even more worrying - more lost hair and splintering of teeth.
    I've since found that after a period of slumber, the render will move to completion, but it's very frustrating when the machine controls things and I can't.
    Is this a bug in 2008, as I didn't seem to have a problem like this with 9.1? If so, is this likely to be fixed soon? If not, does anyone have any hints on how to resolve this?
    Frank Y
    All AUGI, all the time Les Therrien's Avatar
    2003-05
    Tecumseh, Canada
    623
    Default Re: Revit 2008 Rendering
    I'm not using 2008 full tilt just yet.
    Are you using the latest build???
    AUGI Addict truevis's Avatar
    2004-07
    Massachusetts, USA
    1,186
    Always save before a starting rendering.
    I noticed the different CPU behavior in RA'08, too.
    I often, in the past, would click the cancel button and press the Esc key over and over in a superstitious manner hoping one of the click would catch -- usually did.
  1. slow rendering , in revit 2008
    By rtawadrous in forum Software
    Last Post: 2008-09-23, 06:21 PM
  2. Rendering in 2008
    By -Mills- in forum Revit - Rendering
    Last Post: 2007-12-05, 02:35 PM
  3. Replies: 8
    Last Post: 2007-11-20, 07:31 PM
  4. Rendering in 2008
    By gautamrs in forum Revit - Rendering
    Last Post: 2007-04-30, 03:38 PM
